Arducam 9MP USB Camera Evaluation Kit - CMOS MT9N001 1/2.3-Inch Color Camera Module with USB2 Camera Shield
Arducam 18MP USB Camera Evaluation Kit - CMOS AR1820HS 1/2.3−inch Color Camera with USB3.0 Camera Shield Plus
EK013
  • Note: The Camera Evaluation Kit needs a configuration file (sent via shipping notice) and isn’t plug-and-play.
  • Note: The product has been changed and the information?will be?updated soon.
    $319.99
    Arducam AR1820HS camera breakout incorporates ON Semiconductor 1/2.3−inch CMOS active−pixel digital imaging sensor AR1820HS with 1.25um x 1.25um A-PixHS™ BSI Pixel and it can support 18-megapixel (4912H x 3684V) digital still images.
    Features:
    • Optical format: 1/2.3−inch
    • Active pixels: 4912H x 3684V
    • Pixel size: 1.25um x 1.25um
    • Color filter array: RGB Bayer pattern
    • ADC resolution: 12−bit, on−chip
    • Responsivity: 0.62 V/lux−sec (545 nm)
    • Dynamic range: 65.8 dB
    • SNRMAX: 36.3 dB
    • Output Interface: USB 2.0
    • Frame Rate: 60 fps
    • Lens Default: low distortion M12 lens (Part Number: M23390H08)
    • FoV: 92°(D)×79°(H)×63.7°(V)
    • IR Sensitive: build-in 650nm IR filter, none sensitive to IR light
    Application:
    • Digital video cameras
    • Digital still cameras
    • Industrial camera
    • Medical camera
    • Microscopy camera
    • UAV camera
    Documentation:
    Arducam Camera Evaluation Kit - Windows Driver Installation
    Arducam Camera Evaluation Kit - SDK&API
    Datasheet_sensor.pdf
    18MP AR1820HS
    Introduction Arducam AR1820HS camera breakout incorporates ON Semiconductor 1/2.3−inch CMOS active−pixel digital imaging sensor AR1820HS with 1.25um x 1.25um A-PixHS™ BSI Pixel . It can support 18-megapixel (4912H x 3684V) digital still images at 24 fps and a 1080p plus additional 27 percent pixels for electronic image stabilization (2448H x 1378V) in digital video mode […]
    Package Including:
    • 1 pcs Arducam CMOS AR1820HS 1/2.3−inch 18MP Color Camera Module
    • 1 pcs Arducam USB3.0 camera shield plus
    • 1 pcs USB3 Cable
    Lens Options
    LN059
    LN036
    LN058
    LN024
    LN053
    LN033
    LN069
    LN064
    LN056 LN031 LN074
    Part No:
    M17350H08
    M2025ZM02
    M231250H03
    M2306ZM13
    M23390H08
    M23356H09
    M23270H10
    M23325H12
    M23272M14
    M25156H18
    M27150H19
    Optical Format 1/2.3' 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3' 1/2.3'
    EFL(mm) 35.00 25.00  12.50 6.00 3.90 3.56 2.70 3.25 2.27 1.56 1.50
    BFL(mm) 5.50 5.20  2.11 7.56 4.49 5.92 4.97 4.10 3.01 4.30 5.19
    Construction 5G 6G 6G+IR 6G+IR 6G+IR 4G3P+IR 5G2P+IR 7G+IR 8G+IR 6G+IR 9G+IR
    F/NO 3.0 2.0  2.35 2.0 2.8 2.5 2.8 2.2 2.5 2.0 1.8
    HFOV on 1/2.3‘’ Cam 8° 20° 30° 50° 75° 90° 100° 120° 140° 180° 190°
    IR filter No IR filter No IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter
    MOD 0.35m 0.20m  0.30m 0.30m 0.30m 0.20m 0.30m 0.30m 0.20m 0.20m 0.30m
    Size(mm)
    22x 29.3 17 x 21 14 x 22.72 16x 16.41 14x 18.67 14x 16.3 16x 18.43 17x 19 17.2x 22 20x 17.3 24x 16.9
    NOTE: The M12 Lens kit for the HQ/AR1820HS Camera module, please check LK003, 6 lenses are included.
