This Arducam quadrascopic camera bundle incorporates four 1MP OV9782 global shutter cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam - The Arducam Camarray HAT. As the upgraded version of Arducam Synched Stereo Camarray HAT, the Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules to be interfaced to a single MIPI CSI-2 slot on prevailing single-board computers like Raspberry Pi, Jetson Board. Also, as the Camarray HAT releases, Arducam starts to support a variable baseline for stereo camera applications with some modified Arducam camera modules, such as those OV9782 ones included in this bundle. Since no shared camera board or clock-sharing soldering is required for the image sensors, you can kick off your prototyping for stereo camera applications and then decide the optimal baseline. This camera can only get four images. Arducam also accepts subsequent customizations for your stereo camera applications.
| Support Platform | Raspberry Pi and Jetson Board |
| Output/CSI-2 Speed | x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane |
| ISP Support | Supported on Raspberry Pi, Not supported on Nvidia Jetson |
| External Trigger | Support |
| Aggregate mode | Full Spelling |
| Frame Rate(On Raspberry Pi) | RAW8: 5120x800@45fps, 5120x720@50fps, 2560x400@150fps; RAW10: 5120x800@35fps, 5120x720@40fps |
| Frame Rates(On NVIDIA Jetson)* | RAW8: 5120x800@45fps, 5120x720@50fps, 2560x400@150fps; RAW10: 5120x800@35fps, 5120x720@40fps |
| Image Sensor | Color Global Shutter OV9782 |
| Pixel Size | 3 μm x 3 μm |
| Active Array Size | 1280 x 800 |
| Optical Size | 1/4 inch |
| Focusing Range | 30cm ~ infinite |
| IR Sensitive | Integral IR-cut filter, visible light only |
| Camera Board Size | 24mm x 25mm |
| Camarray Hat Size | 65 x 55 mm |
| Optical Format | 1/2.7” |
| Distortion | <1% |
| Effective Focal Length | 2.8mm |
| FOV on 1/4” RPi Camera | 75° (H) |
| F/NO | 2.8 |
| Lens Mount | M12 |
| Lens Size | 14mm x 15.6mm |
| Lens Weight | 4g |
*:JetPack4.6/L4T32.6.1 on NVIDIA Jetson Board
Used on Pi:
1.Introduction This Arducam Camarray HAT (supports four inputs) is an upgraded version of the Arducam synchronous stereo camera HAT (supports two inputs). This quad-camera bundle kit aggregates four OV9782 color cameras into one video stream, compared to its counterpart OV9282 monochrome quad-camera bundle kit. So that it is completely synchronized, the output is a standard MIPI CSI-2 interface, which can be connected to Raspberry Pi, Jetson Nano, Jetsno NX, and other platforms. 2.Hardware Follow the picture below for hardware connection (refer to the picture below for four-camera OV9281, only the camera is different). […]
Used on Jetson Board:
1.Introduction This Arducam Camarray HAT (supports four inputs) is an upgraded version of the Arducam synchronous stereo camera HAT (supports two inputs). This quad-camera bundle kit aggregates four OV9782 color cameras into one video stream, compared to its counterpart OV9282 monochrome quad-camera bundle kit. So that it is completely synchronized, the output is a standard MIPI CSI-2 interface, which can be connected to Raspberry Pi, Jetson Nano, Jetsno NX, and other platforms. 2.Hardware Connect the hardware according to the figure below (refer to the four-camera OV9281 in the picture below, only the camera […]
Arducam Camarray Solution Showcase:
