[Discontinued] Arducam 20MP IMX283 Camera module with C mount lens for DepthAI OAK
[Discontinued] Arducam 1MP OV9282 Mono global shutter drop-in replacement for DepthAI OAK-D(NoIR)
[Discontinued] Arducam 12MP IMX477 MINI High Quality Camera with M12 mount lens and adapter board for DepthAI OAK
B0300
Discontinued, check alternative item B0346.
$79.99
This Arducam 12MP IMX477 MINI High Quality Camera with M12 mount lens camera module is designed for DepthAI OAK,
- Sensor: IMX477
- Optical Format: 1/2.3" (diagonal 7.857mm)
- Resolution: 4056(H) x 3040(V) 12.3MP
- Pixel Size: 1.55um x 1.55um
- IR Sensitivity: Visible light
- Interface: 4-lane MIPI CSI-2
- Maximum image transfer rate: 4K@60 fps
- Default Lens Mount: M12 Mount(SKU:LN053)
- Format: 1/2.3 inch
- Focal Length: 3.9mm
- Aperture (F): F2.8
- Field of View (FOV): 75° (H)
- Mount: M12 Mount
- Back Focal Length: 4.49mm
- MOD: 0.1m Dimension: Φ14×18.67mm
- Weight: 5g
  • Camera board
- Board Size: 24mm×25mm
Lens Options
LN059
LN036
LN058
LN024
LN053
LN033
LN069
LN064
LN056 LN031 LN074
Part No:
M17350H08
M2025ZM02
M231250H03
M2306ZM13
M23390H08
M23356H09
M23270H10
M23325H12
M23272M14
M25156H18
M27150H19
Optical Format 1/2.3' 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3' 1/2.3'
EFL(mm) 35.00 25.00  12.50 6.00 3.90 3.56 2.70 3.25 2.27 1.56 1.50
BFL(mm) 5.50 5.20  2.11 7.56 4.49 5.92 4.97 4.10 3.01 4.30 5.19
Construction 5G 6G 6G+IR 6G+IR 6G+IR 4G3P+IR 5G2P+IR 7G+IR 8G+IR 6G+IR 9G+IR
F/NO 3.0 2.0  2.35 2.0 2.8 2.5 2.8 2.2 2.5 2.0 1.8
HFOV on 1/2.3‘’ Cam 8° 20° 30° 50° 75° 90° 100° 120° 140° 180° 190°
IR filter No IR filter No IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter
MOD 0.35m 0.20m  0.30m 0.30m 0.30m 0.20m 0.30m 0.30m 0.20m 0.20m 0.30m
Size(mm)
22x 29.3 17 x 21 14 x 22.72 16x 16.41 14x 18.67 14x 16.3 16x 18.43 17x 19 17.2x 22 20x 17.3 24x 16.9
NOTE: The M12 Lens kit for the HQ/AR1820HS Camera module, please check LK003, 6 lenses are included.
  • 1 pcs 12.3MP IMX477 color camera module for DepthAI OAK
  • 1 pcs 22pin-26pin adapter board
  • 1 pcs 150mm/12inch 26pin to 26pin camera cable(same side)
  • 1 pcs 80mm/3.1inch 22pin camera cable
