Arducam 1080P Low Light WDR Ultra Wide Angle USB Camera Module for Computer, 2MP CMOS IMX291 160 Degree Fisheye Mini UVC USB2.0 Spy Webcam Board with Microphone, 3.3ft Cable for Windows Linux Mac OS
1080P Low Light Wide Angle USB Camera Module with Microphone for Computer, 2MP 1/2.8" CMOS IMX291 100 Degree Mini UVC USB2.0 Webcam
Arducam 1080P Low Light WDR USB Camera Module for Computer, 2MP 1/2.8” CMOS IMX291 120 Degree Wide Angle Mini UVC Webcam Board with Microphone
B0201
HD Resolution and Low Light: This camera adopts the SONY 2MP IMX291 Color COMS sensor with an 80dB wide dynamic range, can capture the minimum illumination 0.001Lux.
Wide Angle: High quality 120 degree wide view angle (diagonal) M12 lens with IR filter.
Capture Video with Audio: High frame rates, H.264 30fps@1920×1080; MJPG 30fps@1920×1080; YUY2 30fps@640x 480; Audio, Single microphone (optional dual channel).
Plug&Play: UVC-compliant, support Windows XP/7/8/10, Linux, and Mac OS, just connect the camera to PC, laptop or Raspberry Pi with the USB cable without extra drivers to be installed.
Applications: this tiny camera board can be installed in the most hidden and narrow position for a home video surveillance system, day&night low light vision security camera system, dashcam or other machine vision application.
Arducam B0201 is a new member of the Arducam’s USB camera family. It’s a 2MP, based on the 1/2.8” Sony IMX291 image sensor, UVC compliant USB 2.0 camera.
This SONY 2MP IMX291 color COMS sensor produces the camera with an 80DB wide dynamic range, can capture the minimum illumination 0.001Lux, which gives you a wider angle of view and clearer visual joy for day and night.
NOTE: The M12 Lens kit for the USB Camera module, please checkLK005, 10 lenses are included.
NOTE: For the sample order, please order the lens you need to replace separately andContact usin advance for customization if you would like to replace the lenses on the Camera board.
3D drawing.step
1 × 2MP IMX291 USB 2.0 camera board
1 × 3.3ft (1M) USB 2.0 cable
