[Discontinued] Arducam 1080P Day and Night Vision USB Camera with Metal Case
[Discontinued] 2MP AR0230 WDR USB Camera Module with Metal Case and M12 Lens for Raspberry Pi, Windows, Linux, Mac OS, Android
[Discontinued] 12.3MP 477P Mini HQ Camera Module with M12 Lens for NVIDIA Jetson Nano, Xavier NX, and NVIDIA Orin NX/AGX Orin
B0455
Discontinued, check alternative item B0251
  • High-Res: Based on 12MP high resolution color image sensor.
  • Flexible Vision: Mini and Lightweight: 24mm x 25mm. Especially suitable for narrow space.
  • More than HD: Armed with a 75-degree horizontal view low distortion HD M12 Lens.
  • High Compatibility: Compatible with NVIDIA Jetson Nano/Xavier NX/Orin NX/AGX Orin.
  • Time&Cost Saving: Ready to use. Save you time and cost with our camera module.
$64.99
Arducam released this tiny-size camera module for NVIDIA Jetson Nano/Xavier NX to make High-Quality camera module work on applications with size and weight limits. It is a 24mm x 25mm camera board, and armed with a low-distortion M12 mount lens. Customers can natively use this camera module on Jetson Nano/Xavier NX with hardware ISP features.
Currently, NVIDIA official has released the NVIDIA Jetson Orin series developer board. We have also adapted the camera into the NVIDIA Jetson Orin NX/AGX Orin kernel based on it.
★KERNEL CAMERA DRIVER USED
  • UAV/Drones/FPV camera
  • Machine Vision
  • Robotics
  • Face Recognition
  • Defect Detection
  • High Resolution Camera: Adopts a 1/2.3" 12 Megapixel high resolution image sensor for sharp image. Max. still resolution: 4056 x 3040;
  • Mini Sized HQ Cam: Mini and Lightweight: 24mm x 25mm. Flexible camera module, mounted an M12 lens, perfect for the camera applications where high resolution is required, but size and weight are limited, such as model airplane.
  • More Than Ultra HD: Comes with a low-distortion M12 lens with a FOV of 75°(H), which can capture UHD images while maintaining reality.
  • High Compatibility: Specially designed for NVIDIA Jetson Platfom. Support NVIDIA Jetson Nano, Xavier NX, and NVIDIA Orin NX/AGX Orin on specific JetPack Version.
  • Working Out of Box: Save time and effort with our camera modules that are ready to use, featuring standard form factor pinout for easy integration into your existing setup
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focal Length 3.9mm
Field of View(FOV) 88°(D)×75°(H)
Lens Mount M12
Electrical & Mechanical
Camera Board Size 25 × 24mm
  • 1 x 12MP High-Res Camera Module with M12 Lens
  • 1 x 150mm/5.9inch 15pin to 22pin FPC cable
  • 1 x 150mm/5.9inch 22pin to 22pin FPC cable
  • No SBC board is included in the package
  • The camera needs a corresponding driver to access it. Please refer to the following documentation to run the camera.
