Discontinued, check alternative item B0490.
This camera belongs to Arducam's USB 2.0 camera series, specifically designed for night vision applications. Featuring a 940@650nm dual-pass filter and a photosensitive resistor, it intelligently adjusts to lighting conditions. In low light, the IR LED activates, delivering black-and-white night vision with a 3-meter range. In daylight, it captures color images using visible light and around 650nm.
The camera comes with a high-definition lens and a dual-pass filter, providing a wide 105° field of view for comprehensive monitoring.
The Arducam USB 2.0 camera is effortlessly plug-and-play. Simply connect it to any USB 2.0 port, and you're good to go. There's no need for complex installations or driver downloads. Whether you're a tech novice or a seasoned pro, our USB 2.0 camera ensures that capturing moments and participating in video conferences is a seamless and hassle-free experience.
| Image Sensor | |
| Sensor | OV2710 |
| Still Resolution | 2 Megapixels |
| Color Filter Type | Color/Mono |
| Shutter Type | Rolling |
| Optical Size | 1/2.7" |
| Output Format | MJPG/YUY2 |
| Pixel Size | 3 µm x 3 µm |
| Sensor Active Area | 1920(H)×1080(V) |
| Max Frame Rate | MJPG: 30fps@320*240, 352*288, 640*480, 800*600, 1024*768, 1280*720, 1280*960, 1280*1024, 1920*1080 YUY2: 30fps@320*240,352*288; 15fps@640*480; 20fps@800*600; 10fps@1024*768, 1280*720; 5fps@1280*960,1280*1024,1920*1080 |
| Lens | |
| Focus Type | Manual Focus |
| FOV | 105°(D)×90°(H)×74°(V) |
| Lens Mount | M12 Mount |
| F.NO | F1.0 |
| E.F.L | 3.9mm |
| IR Sensitivity | Dual Bandpass Filter Visible + 940nm NIR |
| USB Interface | |
| Interface | USB 2.0 Device |
| Connector | B4B-ZR |
| Power Requirements | Max: 1.6W |
| Camera Board Size | 38×38mm, 28×28mm with case |
| Recommend Sample Application | Amcap for Windows |
| UVC Controls | Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance, Backlight Contrast, Gain, Exposure, |
