Arducam 12MP Multi-Camera Kit for NVIDIA Jetson AGX Orin
[Discontinued] 12.3MP 477M MINI Wide Angle Camera Module for Nvidia Jetson Nano/Xavier NX
12.3MP 477M HQ Camera Module with 158°(D) M12 Wide Angle Lens for NVIDIA Jetson Orin NX/AGX Orin
B0466N
  • Based on a 1/2.3-inch 12-megapixel CMOS for sharp images
  • Maximum still resolution: 4056(H)×3040(V)
  • Mini size: same size (25*24mm) and mounting holes as Raspberry Pi V2
  • With an interchangeable 158°(D) M12 lens, captures a wider field of view and UHD images.
$49.99
Arducam presents a breakthrough in camera technology with this tiny-sized camera module designed specifically for NVIDIA Jetson. With size and weight constraints in mind, this high-quality camera module is perfect for applications where space is limited.
Measuring just 24mm x 25mm, this camera board features a wide-angle M12 mounting lens, providing customers with the flexibility to capture a broader field of view. Compatible with the hardware ISP capability on Nvidia Jetson Board, this camera module delivers exceptional imaging performance.
We are excited to announce that we have adapted this camera module for the latest NVIDIA Jetson Orin series of development boards, including Orin NX and AGX Orin core. This ensures compatibility and unlocks new possibilities for camera applications with the cutting-edge NVIDIA technology.
★KERNEL CAMERA DRIVER USED
  • Astrophotography
  • Surveillance cameras
  • FA cameras
  • High Quality Camera: Capture sharp images with a 1/2.3-inch 12MP CMOS, ensuring exceptional image quality.
  • More than HD: Max still resolution: 4056 x 3040. Video modes: 4032x3040@30fps, 3840x2160@30fps, 1920x1080@60fps
  • Mini size: Compact and convenient, this camera is the same size as Raspberry Pi V2, making it easy to integrate into your projects.
  • Wide angle lens: Capture a wider field of view with the interchangeable M12 lens and a 158°(D) FOV, delivering UHD images with an immersive perspective.
  • Broad compatibility: Specially designed for NVIDIA Jetson Platform. Support Nvidia Jetson Board on specific JetPack Version.
Image Sensor 477M
Resolution 12.3MP
Optical Size 1/2.3"
Max Still Resolution 4056(H)×3040(V)
Pixel Size 1.55μm x 1.55μm
Support Platform Orin NX/Orin Nano/AGX Orin
Shutter Type Rolling Shutter
Color Filter Array Color
Video Modes Orin NX/Orin Nano/AGX Orin:
  • L4t 32.x: 4032x3040@30fps, 3840x2160@30fps, 1920x1080@60fps
  • L4t 35.x: 4032x3040@20fps, 3840x2160@30fps, 1920x1080@60fps
  • Output Format RAW8/RAW10
    F.NO 2.8±5%
    Focal Length 2.87mm
    Lens Size M12*P0.5mm
    Field of View(FOV) 158°(D)×120°(H)×105°(V)
    Camera Board Size 25 × 24mm
    • 1 x 12MP 477M Camera Module
    • 1 x 15-22pin FPC Cable
    • 1 x 22-22pin FPC Cable
