Arducam IMX477P V3Link FPD-Link SerDes Camera Kit for NVIDIA® Jetson Orin NX, Orin Nano
Arducam IMX219 Multi-Camera Kit for the NVIDIA Jetson AGX Orin
Arducam 12MP Multi-Camera Kit for NVIDIA Jetson AGX Orin
B0473
  • Designed for the NVIDIA Jetson AGX Orin Dev kit
  • Based on 12MP 477 CMOS
  • Built-in ISP image processing
  • Support up to 6 cameras at the same time
  • All 6 cameras support video streaming individually
$249.00
Arducam 12MP Camera Kit - A multi-camera solution designed for the NVIDIA Jetson AGX Orin. The kit comes with 6 × 12 MP camera modules with case, 6 × 30cm 15-22pin FPCs, 1× camera adapter with 6 CSI-2 interfaces.
A distinctive feature of the AGX Orin is its lack of a native camera interface. Recognizing this gap, we present this innovative camera adapter board. Outfitted with 6 CSI-2 15pin connectors, and this adapter empowers you to seamlessly integrate up to 6 camera modules. A remarkable advantage of this multi-camera setup is the independent operation of each camera module. Please note that these modules must be of the same model and cannot be mixed to ensure optimal performance.
This breakthrough engineering ensures that you can harness the full potential of each camera module simultaneously, capturing diverse perspectives and enhancing your project's scope.
  • Machine Vision
  • Automated Optical Inspection
  • 3D Scanning and Metrology
  • Robotics and Automation
  • Biomedical Imaging
Video Modes L4t 32.x: 4032x3040@30fps, 3840x2160@30fps, 1920x1080@60fps
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
IR Sensitivity Integral IR-Cut Filter, visible light only
FOV 120°(D)
Lens Type Stock Lens
E.F.L 2.75mm
Electrical & Mechanical
Camera Board Size 25 × 24 mm
Peaking Current 300mA
  • 6 x 12MP Camera Module with Case
  • 6 x 30cm 15-22pin FPC
  • 1 x Camera Adapter for NVIDIA Jetson AGX Orin
  • 1 x Screw Pack
  • For NVIDIA Jetson Official Developer Kits only, third-party carrier boards are not supported.
  • The camera kit supports JetPack 5.1.1/L4T 35.3.1 and above. Additional driver configuration is required before use, see the below documentation for details.
