Arducam 5MP OV5647 Miniature Camera with Flex Cable for Raspberry Pi Zero and Compute Module (NoIR)
OCam Edge AI Camera: Video Intelligence for Smart IoT & Beyond
[Discontinued] 12.3MP 477M MINI Wide Angle Camera Module for Nvidia Jetson Nano/Xavier NX
B0303N
Discontinued, check alternative item B0303R
  • Wide Angle: 120°(DFOV)
  • High Resolution: Based on 12.3MP 477M image sensor
  • Mini Size: 24mm x 25mm camera board, easy to move
  • East to Use: Just need to install the corresponding driver for it
$39.99
IMX477 camera modules have the high resolution.But most of IMX477 cameras generally have larger camera boards and larger lenses. In order to make the IMX477 camera more convenient and space-saving, we have developed this camera based on the 477M image sensor. The 477M and IMX477 have exactly the same optical size and pixels, and the frame rate at different resolutions is also the same. We equipped a 1/2.3 inch 6p lens on this basis. The camera board is about 24x25mm, which makes it more flexible and convenient to move and transfer. Through the specially equipped lens and 477M sensor, we have achieved the compatibility of high pixel and tiny size.
★KERNEL CAMERA DRIVER USED
  • DSLR Camera Control
  • Time-lapse Machine
  • Security System
  • Smart Video Doorbell
  • Face Recognition
  • Instant (Polaroid-Style) Camera, etc.
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focal Length 2.75mm
Field of View(FOV) 120°(D)
Lens Mount /
Camera Board Size 25 × 24mm
  • 1 x 12.3MP 477M Camera Module for Nvidia Jetson
  • 1 x 150mm 15pin to 22pin flex cable
  • 1 x 150mm 22pin to 22pin flex cable
  • Nvidia Jetson Board is not included in the package
  • The Camera needs corresponding driver to be used, please refer to the following documentation to install the driver and use the official command to run the camera
