2.3MP USB3.0 UVC Global Shutter Dual-Camera Bundle Kit for Robotics & Machine Vision, Stereo Depth & Onboard ISP
USB2.0 UVC Camera Module, 2.3MP Global Shutter, with Onboard ISP for Robotics & Machine Vision
Sync Stereo Global Shutter Dual-Camera Bundle Kit for NVIDIA Jetson Orin Nano/NX, 2.3MP High res. & Onboard ISP for Robotics & Machine Vision
B0577
  • [Global Shutter] Features the selected global shutter sensor for imaging of fast-moving objects.
  • [Camera bundle kit] Includes two pre-calibrated M12 wide-angle lens cameras ready for PoC or mass deployment.
  • [Sync Stereo] Hardware-synchronized stereo pair with high accuracy for precision alignment and depth.
  • [Onboard ISP] Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto)
  • [Camera extension] Up to 30cm extension for each camera by MIPI cable
  • [Variable Baseline] The distance between the two cameras can be physically adjusted.
$299.99
This Jetson-optimized kit integrates dual selected global shutter cameras (2.3MP, 1920×1200) with hardware synchronization to deliver depth accuracy for robotics and industrial automation. Pre-calibrated with M12 wide-angle lenses and MIPI cable extensions (30cm per camera), the bundle supports flexible mounting in confined spaces—ideal for robotic arms or AGV bumper installations. The onboard ISP provides real-time control over exposure, gain, and white balance (auto/manual).
    Industrial & Robotics
  • [Humanoid] Various of humanoid robotics applications
  • [Machine Vision Inspection] Detecting defects, labels, or alignment in manufacturing lines
  • [Robotic Navigation] Visual guidance for mobile robots and AGVs (Automated Guided Vehicles)
  • [Barcode/QR Code Scanning] High-speed decoding in logistics and packaging systems
  • [Pick-and-Place Systems] Real-time object tracking for automation arms
  • [Other Robotics related applications]
  • Global Shutter Technology Selected Global Shutter Sensor: Optimized for capturing clear images of fast-moving objects, ensuring minimal motion blur and high precision.
  • Camera Bundle Kit Pre-Calibrated Dual Cameras: Includes two M12 wide-angle lens cameras, ready for immediate deployment in proof of concept (PoC) or mass production scenarios.
  • Sync Stereo Configuration Hardware-Synchronized Stereo Pair: Ensures high accuracy for depth perception and alignment, critical for applications like 3D mapping and robotic vision.
  • Onboard Image Signal Processing (ISP) Advanced ISP Features: Offers controls for brightness, contrast, saturation, auto/manual white balance, gain, and exposure (manual/auto) to enhance image quality.
  • Camera Extension Capability MIPI Cable Extension: Allows for up to 30cm extension for each camera, providing flexibility in camera placement without compromising performance.
  • Variable Baseline In TrueSight stereo kits, the distance between the two global shutter cameras — the baseline — can be physically adjusted to suit your specific depth range and accuracy needs.
Sensor 2.3MP Color Image Sensor
Shutter Type Global Shutter
Optical Size 1/2.6"
Output Format YUV
Pixel Size 3 μm × 3 μm
Sensor Active Area 1920 × 1200 pixels
Resolution&Frame Rate 3840x1200@30fps, 2560x720@30fps, 1280x480@30fps
FOV(DxHxV) 110°(D)×98°(H)×75°(V)
F.NO F2.4±5%
E.F.L 2.8±5% mm
Default Focus Range 0.3m to INF
TV-Distortion <-1.3%
Operating Voltage 3.3V
Power Consumption Max: 1.3W
Camera Board Size 34mm x 34mm
Camera Interface MIPI CSI-2
Supported Platform NVIDIA Orin Nano/NX
  • 2 x Arducam 2.3MP Color Global Shutter Camera Module
  • 1 x Arducam Jetvariety Camera Adapter Board
  • 2 x 20cm Module Extension Cable
  • 1 x 15cm 22-22pin Ribbon Cable
    This kit supports using brackets to secure each two camera modules (the modules can still move freely horizontally). For 3D files of the brackets, check 3D Drawings in the Documentation section below. If you need ready-made brackets, please contact Arducam Sales
