Sync Stereo Global Shutter Dual-Camera Bundle Kit for NVIDIA Jetson Orin Nano/NX, 2.3MP High res. & Onboard ISP for Robotics & Machine Vision
Global Shutter Camera Module for NVIDIA Jetson Orin Nano/NX, 2.3MP High res. & Onboard ISP for Robotics & Machine Vision
USB2.0 UVC Camera Module, 2.3MP Global Shutter, with Onboard ISP for Robotics & Machine Vision
B0578
  • [Global Shutter] Features the selected global shutter sensor for imaging of fast-moving objects.
  • [Plug & Play] Standard USB2.0 UVC compliance ensures out of box easy use.
  • [Onboard ISP] Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto)
  • [High Frame Rate] Delivers 1080p@90fps streaming for latency-sensitive applications
  • [High res.] 2.3MP (1920×1200) resolution delivers crisp detail for precision machine vision tasks
$99.99
This USB2.0 UVC-compliant module leverages the selected global shutter sensor (2.3MP, 1920×1200) to deliver motion artifact-free imaging at 1080p@90fps—ideal for high-speed robotics (e.g., pick-and-place, drone navigation) where USB3.0 bandwidth is excessive but legacy compatibility is critical. The onboard ISP dynamically optimizes exposure, gain, and white balance (auto/manual modes) to compensate for USB2.0’s 480Mbps bandwidth constraints, ensuring usable frame rates even in low-light industrial environments.
    Industrial & Robotics
  • [Humanoid] Various of humanoid robotics applications
  • [Machine Vision Inspection] Detecting defects, labels, or alignment in manufacturing lines
  • [Robotic Navigation] Visual guidance for mobile robots and AGVs (Automated Guided Vehicles)
  • [Barcode/QR Code Scanning] High-speed decoding in logistics and packaging systems
  • [Pick-and-Place Systems] Real-time object tracking for automation arms
  • [Other Robotics related applications]
  • Global Shutter for Motion Capture Built with the selected global shutter sensor, this camera uses a global shutter to eliminate motion blur, making it ideal for capturing fast-moving objects in robotics, automation, and machine vision applications.
  • Easy Plug & Play via USB2.0 UVC With standard USB2.0 and UVC compliance, the camera works right out of the box on most platforms—no drivers or extra setup required.
  • Onboard ISP Controls Features built-in image processing with adjustable brightness, contrast, saturation, white balance (auto/manual), gain, and exposure (auto/manual), offering flexible image tuning for various environments.
  • High Frame Rate Streaming Supports 1080p video at up to 90fps, delivering smooth, low-latency performance for real-time applications like gesture tracking or automated inspection.
  • Crisp 2.3MP Resolution Captures sharp, detailed images at 1920×1200 resolution—ideal for precision tasks in machine vision and quality control.
Sensor 2.3MP Color Image Sensor
Shutter Type Global Shutter
Optical Size 1/2.6"
Output Format MJPG/YUV
Pixel Size 3 μm × 3 μm
Sensor Active Area 1920 × 1200 pixels
Frame Rate(MJPG) 1920x1200@80fps, 1920x1080@90fps; 1280x720@90fps, 960x600@100fps; 640x480@100fps, 320x240@100fps;
Frame Rate(AI Resolution(YUV)) 640x480@30fps, 320x240@30fps; 320x320@30fps,128x128@30fps; 96x96@30fps;
FOV(DxHxV) 110°(D)×98°(H)×75°(V)
F.NO F2.4±5%
E.F.L 2.8±5% mm
Default Focus Range 0.3m to INF
TV-Distortion <-1.3%
Interface USB 2.0 Device
Connector B4B-ZR JST
Operating Voltage 5V
Power Consumption 1.2W
Camera Board Size 34mmX34mm
UVC Controls Brightness, Contrast, Saturation, Gamma, White Balance(Auto/Manual), Gain, Exposure(Auto/Manual).
  • 1 x Arducam 2.3MP Color Global Shutter USB2 UVC Camera Module
  • This camera module supports the development of external trigger mode and strobe flash output. If you need these functions, please contact arducam for customization.
  • Regarding the compatibility of Android OS device, this product currently only supports limited devices. Please contact our customer service for specific compatibility.
