12MP HDR USB UVC Autofocus Camera Module with Metal Housing, A708
Global Shutter USB2 UVC Camera, Ultra High FPS, VGA Monochrome, Wide Angle, Arducam ezBOX GS
Ultra Low Light USB2.0 Camera Module, 8.3MP 4K Wide Angle, Sony Starvis 2 IMX678, UVC Plug'n'play, Ideal for Surveillance & Night vision
B0587
  • [Sony Starvis 2 Sensor] Equipped with the 8.3MP Sony IMX678 sensor, offering 4K resolution (3840×2160) and exceptional imaging clarity.
  • [Plug & Play Simplicity] USB 2.0 UVC compliant – no drivers required for effortless setup across major platforms like Windows/Linux/Mac/Android.
  • [Superior Low-Light Performance] Optimized for dim environments and near-total darkness, perfect for surveillance and night vision use.
  • [Precision Lens] Pre-installed M12 fixed-focus lens with a wide 100° diagonal field of view for broader scene coverage.
  • [Customization Available] Can be tailored to meet your volume order requirements and support mass deployment.
$119.99
This 8.3MP USB camera module features the Sony Starvis 2 IMX678 sensor, delivering exceptional 4K image quality and outstanding low-light performance. With a wide 100° field of view, UVC-compliant USB 2.0 interface, and true plug-and-play compatibility, it’s an ideal solution for surveillance, security, and night vision applications.
    Surveillance Systems
  • Night Vision Monitoring
  • Smart Home and Office Security
  • Robotics and AGVs
  • Wildlife and Nature Observation
  • Industrial Machine Vision
  • Embedded Vision Projects
  • [Sony Starvis 2 Sensor] Powered by the advanced Sony IMX678 image sensor from the Starvis 2 series, this camera delivers stunning 8.3MP (3840×2160) resolution at 4K quality. Designed with back-illuminated pixel technology, it ensures excellent image clarity even in scenes with complex lighting, making it a reliable option for detailed video capture in surveillance and vision-critical applications.
  • [Plug & Play Simplicity] This camera module supports USB 2.0 UVC protocol and requires no additional drivers for use on Windows, Linux, or Android systems. Its true plug-and-play compatibility makes it an ideal choice for quick prototyping, system integration, and long-term deployment without complicated software installation or configuration.
  • [Superior Low-Light Performance] With enhanced sensitivity in both visible and near-infrared spectrums, this module excels in ultra-low light and nighttime environments. Whether it's used indoors with minimal lighting or outdoors in total darkness, it consistently delivers clear and noise-reduced images, making it ideal for 24/7 monitoring and night vision projects.
  • [Precision Wide-Angle Lens] Outfitted with a high-quality M12 fixed-focus lens, this camera offers a broad 100° diagonal field of view. The lens is pre-calibrated for optimized focus, ensuring sharp visuals across the frame while covering more area per frame—perfect for wide-scene surveillance, room monitoring, or machine vision applications.
  • [Customization Available] While the camera core remains based on the Sony IMX678 sensor, we offer customization options for other key components to suit your application needs. These include adjustable form factor (PCB layout and size), housing design for specific enclosures or environmental conditions, and lens options to match your desired field of view or focus requirements. Ideal for volume orders and tailored system integration.
Sensor SONY's STARVIS 2 Image Sensor
Max Still Resolution 8.3 Megapixels
Optical Size 1/1.8″
Output Format MJPG/YUV
Pixel Size 2 µm x 2 µm
Sensor Active Area 3856(H) x 2180(V)
Frame Rate(MJPG) 3840x2160@25fps, 1920x1080@60fps; 1280x720@60fps, 640x480@60fps; 320x240@60fps;
Frame Rate(AI Resolution) 640x480@30fps, 320x320@30fps; 320x240@30fps, 128x128@30fps; 96x96@30fps
FOV 100°(D) × 88°(H) × 72(V)
Lens Mount M12*P0.5
F.NO F1.65±10%
E.F.L 4.9±5%mm
Default Focus Range 3m-INF
Interface USB 2.0 Device
Connector B4B-ZR JST
Operating Voltage 5 V
Power Consumption 1.2W
Camera Board Size 34mm x 34mm
Supported OS Windows, Linux, Android
UVC Controls Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance(Auto/Manual), Backlight Contrast, Low Light Compensation, Gain, Exposure(Auto/Manual).
Certification CE/RoHS
  • 1 x Arducam 4K Ultra Low Light USB2 UVC Camera Module
  • Quick Start Guide
  • 3D Drawing
