12MP USB UVC Fixed-Focus Camera Module, A708
Ultra Low Light USB2.0 Camera Module, 8.3MP 4K Wide Angle, Sony Starvis 2 IMX678, UVC Plug'n'play, Ideal for Surveillance & Night vision
12MP HDR USB UVC Autofocus Camera Module with Metal Housing, A708
B030401
  • [HDR] Features the High Dynamic Range function.
  • [High Resolution] 12MP, Max resolution: 4608 × 2592
  • [Fixed Focus] Equipped with High-Quality Fixed Focus Lens. Integral 650nm IR-cut filter.
arducam shipping payment 1
$49.98
A 12MP USB camera module with HDR support and a fixed-focus lens, designed for high-quality imaging up to 4608×2592 resolution. Its integrated 650nm IR-cut filter ensures accurate color performance, while the sturdy metal housing provides effective heat dissipation and protection. With plug-and-play compatibility on Windows, Linux, Android, and macOS—no driver required—the A708 is a reliable UVC solution for applications demanding clarity, durability, and wide dynamic range.
  • Robotics
  • Precision Agriculture
  • [Plug-and-Play]
    This 12MP camera module offers hassle-free plug-and-play operation across Windows, Linux, Android, and macOS platforms. No additional drivers or software are required—simply connect via USB and start capturing high-quality images instantly.
  • [HDR]
    Equipped with High Dynamic Range (HDR) technology, the camera captures well-balanced images that retain detail in both bright and shadowed areas, delivering superior image quality in challenging lighting environments.
  • [High Resolution]
    Featuring a 12MP sensor, the camera produces sharp still images with a maximum resolution of 4608 × 2592 pixels, ensuring clear and detailed visuals suitable for demanding applications.
  • [Fixed Focus]
    The module is fitted with a high-quality fixed-focus lens designed for consistent sharpness at a set focal distance. An integrated 650nm IR-cut filter enhances color accuracy by blocking infrared light, making it ideal for true-to-life color reproduction.
  • [Metal Case]
    Housed in a sturdy metal enclosure, the camera benefits from effective heat dissipation and robust protection. This metal housing ensures reliable performance and product longevity, even under extended use or harsh conditions.
General Sepcs B030401 B0304-1
Still Resolution 12MP 12MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.43" 1/2.43"
Output Format MJPG/YUY2 MJPG
Pixel Size 1.4µm x 1.4µm 1.4um x 1.4um
Sensor Active Area 4608(H)x2592(V) 4608(H)x2592(V)
Frame Rate(MJPG) 4608x2592@15fps, 3840x2160@25fps;
3264x2448@25fps, 2592x1944@30fps;
1920x1080@30fps,1280x720@30fps;
640x480@30fps;
4608x2592@10fps, 2304x1296@30fps;
1920x1080@30fps, 1600x1200@30fps;
1280x720@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
Focus Type Autofocus Fixed Focus
FOV 75°(D)×61°(H)×50°(V) 75°(D)x66°(H)x41°(V)
F.NO F1.8 F1.8
E.F.L 3.95mm 4.74mm
Default Focus Range 10cm-∞ 150cm-∞
Operating Voltage 5V 5V
Power Consumption Max: 1.75W Max: 1.5W
Camera Board Size 32mm x 32mm x 1.6mm 24mm x 25mm
HDR Support YES NO
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Lowlight Compensation, Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam IMX708 Fixed Focus Camera Module with UVC adapter board
  • 1 x USB2.0 Cable (1m/3.3ft)
  • If you can't capture the images using Amcap, please try other software such as USB Camera, PotPlayer, etc.
