1% Accuracy RGBD ToF Camera Module – Depth Sensing for Custom Integration
Time of Flight Camera for Raspberry Pi and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0410
  • Pixel-level accuracy: powerful depth/distance measurement.
  • Large working range: 2m/4m optional, and a 10-meter broader coverage with our cable extension kit.
  • Outdoor usable: No worry of interference from ambient light.
  • OpenCV Supported: Supports OpenCV Machine vision library by default.
  • Affordable decency: 3D imaging with primed point clouds at an unexpectedly low cost.
arducam shipping payment 1
$49.99
A Time of Flight camera module featuring a MIPI-CSI 2 connection and offering up to 4-meter measuring range with sub-2cm precision, designed and optimized exclusively for Raspberry Pi & Nvidia Jetson boards.
Quick sum-up about the camera
● Real-time point cloud and depth map.
● Resolution: 240x180@30fps on RPI4/CM4
● Up to 4M measuring distance
● Onboard 940nm laser for both indoor & outdoor uses, no external light source needed.
● V4L2-based video kernel device
● C/C++/Python SDK for userland depth map output and example source code
● ROS ready.
● 38 x 38mm board size
Number of Effective Pixels 240×180
Image Size 1/6″
Max. Frame Rate (Sensor) 120fps
Max. Depth Frame Rate (Raspberry Pi) 30fps, 4-phase
Max. Depth Frame Rate (Nvidia Jetson**) 30fps, 4-phase
Raspberry Pi OS Bookworm/Bullseye (32-bit/64-bit) 01/28/22 or later releases
TDP 3.5W Power supply for Pi should be at least 5V/4A
Supported Platforms*** Pi 5/4/2/3/CM3/4B/Zero W/Zero 2 W/CM4/Nvidia Jetson Board
Modulation Frequency 75MHz/37.5MHz
Viewing Angle 70° Diagonal
Measurement Distance Far Mode: 4m Near Mode: 2m
Light Source 940nm VCSEL illuminator
Board Size 38mm x 38mm
Interface MIPI (2-Lane)
Output Formats 4-phases RAW Frame, Depth Frame, Grayscale Amplitude Frame
Getting Started with Arducam ToF Camera
Getting Started with Arducam ToF Camera (PDF)
Arducam ToF Camera SDK
Point Cloud With Arducam ToF Camera
Getting Started with Nvidia Jetson
Github – Arducam ToF
3D Model of ToF Camera
Packing Including
  • 1 x Arducam ToF Camera Module
  • 1 x FPC 15cm 15pin Cable
  • 1 x 2-pin Dupunt Cable
  • 1 x15cm 15-22pin FPC Cable
*To use the camera on Pi Zero and 2 W, you need this.
** Tested on Jetson Nano/Orin NX/Orin Nano/Xavier NX
***For connection on the NVIDIA Jetson AGX Orin platform, you will need an additional MIPI adapter board. You can contact Arducam sales to obtain one if needed.
FAQ
Is it compatible with all Raspberry Pi models?
Yes, it can work with most Pis. However, with early models, there may be performance drops.
Do I need external light sources?
No, the camera has an onboard laser. (Non-intrusive, safe for the human eye.)
What’s the maximum operating range?
See the full list of FAQs >
