Arducam 5MP OV5647 Mini Camera Module for Raspberry Pi Model A/B/B+, Pi 2, Pi 3, Pi 4, Pi 5 and Pi ZERO
Multi Camera Adapter Module V2.2 for Rasperry Pi Camera Module 3 12MP IMX708 / 5MP OV5647 / 8MP IMX219 / 12MP IMX477 Cameras
Arducam 5MP OV5647 1080p Autofocus Camera Module for Raspberry Pi, Compatible with Pi 5/4/3B+/3
B0176
  • SEE CLOSER: Software-controllable moveable Lens. Shoot objects in millimeter level and in the distance on the same camera, remotely controlled without lens adjustment tool
  • SEE SMARTER: You can adjust the focus freely by the Motorized lens and the Autofocus python scripts powered by OpenCV
  • SEE PRECISELY: Precise manual focus control with UP and DOWN keys on the keyboard to handcraft your pixel accuracy
  • HIGH COMPATIBILITY: 5MP OV5647 sensor camera module, same mounting holes for your drop-in replacements. Support OS like Raspbian, OctoPi, MotionEye, Kali, Ubuntu, and More
$14.99
The official camera modules have fixed-focus lenses, which are either glued or need manual adjustment. However, Arducam thinks that your focus matters and has released this motorized focus camera for Raspberry Pi. This Arducam camera module is designed for you to control the focus on a camera for Raspberry Pi via software, so you can see closer and see where you want to see.
  • IoT cameras
  • Robot cameras
  • Wildlife cameras
  • Can be used in MCU, Raspberry Pi, ARM, DSP, FPGA platforms
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Field of View (FOV) 54°(H), 44°(V)
Focus Type Motorized Focus
Focus Distance 80mm to infinity
Full-frame SLR lens equivalent 35 mm
Dimension 25mm×24 mm
Peak Current 300mA
  • 1 × 5MP OV5647 camera board with motorized lens for Raspberry Pi
  • 1 × Acrylic case for the camera module
  • 1 × 15cm flex ribbon cable for Raspberry Pi Model A&B series
  • 1 × 15cm flex ribbon cable for Raspberry Pi Zero
  • Raspberry Pi Board is not included in the package
  • The camera's autofocus function needs to be operated by using python scripts, etc. Please see the following documentation for detail
  • Contact [email protected] for customization and [email protected] for support
  • Note for Supported Raspberry Pi Boards and OS
    Platform Bookworm(rpicam) Bullseye(libcamera) Buster(raspistill)
    Raspberry Pi 5 √
Other upgraded solutions:
5MP OV5647 Motorized Focus Camera Modules
Introduction Arducam 5MP OV5647 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide. Models in this Series There […]
3D drawing.step
Manual.pdf
Manual.pdf
Note: Camera holder for Creality Ender 3, please check HERE.
pi_camera_auto_focus_thumbnail
Solving the Raspberry Pi Camera V2 Focus Issue with An Auto-Focus Camera Module
The Focus Distance of a V2 Camera Module The viewing distance of the offical Raspberry Pi cameras is 1m to infinity, which means that you will extra works if you need to shoot closer than 1m. Introduction Problems with Fixed Focus In some simple applications, it’s fine to go with a fixed-focus camera. However, that’s […]
GitHub
ArduCAM/RaspberryPi
