Arducam 5MP OV5647 1080P Camera Module with Acrylic Case for Raspberry 5/4/3B+/3 and More
Arducam 5MP OV5647 1080p Autofocus Camera Module for Raspberry Pi, Compatible with Pi 5/4/3B+/3
Arducam 5MP OV5647 Mini Camera Module for Raspberry Pi Model A/B/B+, Pi 2, Pi 3, Pi 4, Pi 5 and Pi ZERO
B0033+B0087
  • Attached with a 12-22pin flexible cable for connecting with Raspberry Pi zero
  • The maximum frame rate achievable on pizero is 30fps
  • It can achieve 1080p30, 720p60 and 640x480p60/90 video on other platforms such as raspberry pi3/4.
was $16.99 Special Price $8.49
The Arducam team now released another add-on mini camera module for Raspberry Pi series boards which is fully compatible with official one.
The board itself is tiny, at around 25mm x 24mm, which makes it perfect for mobile or other applications where size and image quality are important.
It connects to Raspberry Pi by way of a short ribbon cable.
The camera is connected to the BCM2835/BCM2836 processor on the Pi via the CSI bus, which travels along the ribbon cable that attaches the camera board to the Pi.
It attaches to Raspberry Pi by way of one of the two small sockets on the board upper surface.
This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras.
  • Cellular phones, PDAs, Toys
  • PC multimedia
  • Can be used in all Raspberry Pi platforms
  • Digital still cameras,etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Max Frame Rate 30fps
Field of View (FOV) 54°(H), 41°(V)
Focus Length 3.60mm
Full-frame SLR lens equivalent 35 mm
Dimension 25×24 mm
Peak Current 300mA
  • 1pcs 5MP Mini Camera OV5647 Sensor 1080p 720p video for Raspberry Pi Official Board
  • 1pcs 15cm 15pin FPC cable
  • 1pcs 15cm 15pin to 22pin 0.5mm pitch FPC cable
  • Raspberry Pi Development Board is not included in the package
  • Note for Supported Raspberry Pi Boards and OS
    Platform Bookworm(rpicam) Bullseye(libcamera) Buster(raspistill)
    Raspberry Pi 5 √
Selection Guide
Edit
