The Arducam Pivistation 5 is a comprehensive embedded vision kit designed to simplify the development of advanced imaging projects. Integrating the Raspberry Pi 5, it addresses the common challenges of setup complexity and compatibility, providing users with a powerful, ready-to-use solution for various vision applications.
The Arducam Hawkeye camera kit boasts a powerful 64-megapixel sensor, enabling users to capture extremely high-resolution images suitable for detailed analysis and advanced imaging applications. With an integrated autofocus mechanism and up to 10x digital zoom, the Hawkeye ensures sharp, clear images and allows for close-up inspections without compromising quality.
The Pivistation 5 is designed for convenience and efficiency, coming pre-installed with essential software such as OpenCV-Python and TensorFlow. It utilizes the official Raspberry Pi case, which includes a cooling fan for optimal performance and pre-installed tripod hole for easy setup and mobility. This combination of hardware and software ensures a seamless and hassle-free user experience, allowing developers to focus on their projects without worrying about configuration and compatibility issues.
| Image Sensor | |
| Image Sensor | SONY 1/1.7" |
| Still Resolution | 64 MP |
| Color Filter Type | Color |
| Shutter Type | Rolling shutter |
| Optical Size | 1/1.7 inch |
| Sensor Output Format | RAW10 |
| Platform Output Format | JPEG/YUV/RGB/RAW10 |
| Pixel Size | 0.8 μm×0.8 μm |
| Sensor Active Area | 9152(H) × 6944(V) |
| Frame Rate | 1080p30,720p60 and 640×480p60/90 |
| Video Modes (Camera Module) | 9152×6944@2fps, 8000×[email protected], 4624×[email protected], 3840×[email protected], 2312×[email protected], 1920×1080@45fps. | Lens |
| Lens Mount | Stock lens |
| Focus Type | PDAF + CDAF |
| FOV | 84°(D) |
| F.NO | F1.8 |
| E.F.L | 5.1mm |
| Default Focus Range | 8cm-∞ |
| Power Requirements | 7.5W |
| Camera Board Size | 24×25mm |
| Overall Size | 99×70×37 mm |
| Supported OS | Bookworm |
| Pre-installed Software | opencv-python, libopencv-dev (C++ version) libcamera, rpicam-apps C++ essential tools (building environment) TensorFlow (Python)/ PyTorch camera-streamer, arducacm camera server |
| Supported Platform | Raspberry Pi 5 |
Note: *Raspberry Pi 2/3/Zero W may not be able to enable maximum resolution due to RAM, please make sure your platform has RAM greater than or equal to 1G.
