[Discontinued] Arducam 5MP OV5647 Camera Module with M12x0.5 LS-40180 Fisheye Lens for Raspberry Pi 4/3B+/3
[Discontinued] Arducam 1.3MP MT9M001 Infrared HD CMOS Camera Module with Adapter Board
[Discontinued] Arducam 2MP OV2640 1/4" CMOS Sensor Camera Module Adapter Board JPEG Out
B0011
  • High sensitivity for low-light operation.
  • Maxim resolution 1600 x 1200 UXGA at 15 fps
  • Output support for Raw RGB, RGB (RGB565/555),GRB422,YUV (422/420) and YCbCr (4:2:2) formats
  • Easy intergrate with STM32,FPGA,DSP,Arduino etc.
  • Supports image sizes:UXGA,SXGA, SVGA,and any size scaling down from SXGA to 40×30
  • Support real time JPEG compression
$9.99
The OV2640 CAMERA chip image sensor is a low voltage CMOS device that provides the full functionality of a single-chip UXGA(1632X1232) camera and image processor in a small footprint package. The OV2640 provides full-frame,sub-sampled,scaled or windowed 8-bit/10-bit images in a wide range of formats,controlled through the Serial Camera Control Bus (SCCB) interface.
  • Maxim frame rate 30fps at SVGA, 60 fps at CIF
  • Optical size 1/4"
  • Onboard regulator for DVDD,DOVDD,AVDD, only single 3.3V supply needed
  • Output support for Raw RGB, RGB (GRB 4:2:2,RGB565/555), YUV (4:2:2) and YCbCr (4:2:2)formats
  • Supports image sizes: UXGA, SXGA, SVGA, and any size scaling down from SXGA to 40x30
  • Low operating voltage for embedded portable apps
  • Standard SCCB interface
  • Digital Video Port interface, 3.3V LVTTL compatible
  • 20pin 2.54mm(0.1") pin header connector
NOTE:
  • Please contact the seller for more information with the pinout or mating connector and camera adapter board.
2MP OV2640
Introduction Arducam OV2640 camera breakout incorporates Omnivision 1/4−inch CMOS active−pixel digital imaging sensor OV2640 with an active pixel array of 1632 x 1232 including border pixels. The entire system-on-a-chip (SOC) has low power requirements that is particularly suitable for IoT applications. It has onchip AEC/AGC/AWB ISP functions, and supports RAW/YUV/RGB/JPEG different output format. Key Specification […]
Arducam USB3.0 Camera Shield
GitHub
ArduCAM/RaspberryPi
You can purchase this item from Arducam distributors or Amazon store
