MJPEG YUV RGB H.264 UVC Camera
Arducam team now designed a series UVC compliance USB camera for wide range applications such as WDR (wide dynamic range), low noise surveillance camera, high resolution document scanner microscopy camera, H.264 encoding low latency low bitrate wireless camera, endscopy auto focus camera. The camera is designed in two stack boards style board for easy combination between the USB DSP controller and the camera breakout board.
Application
  • IoT cameras
  • Robot cameras
  • Wildlife cameras
  • Documents scanner
  • Surveillance camera
  • Endcope camera
  • Support x86 PC, ARM single board computer
  • Support Windows, Linux, Mac, Android OS
  • Support AEC, AGC, Auto Focus, Adjustable parameters Brightness/Contrast/Color saturation /Definition/Gamma/WB
  • Night vision optional, can support IR Cut and IR board for IR night vision
  • Picture format MJPEG/YUY2/RGB/H.264
  • Fully customizable for different sensors and board size
Specification
  • USB Prototcol : USB2.0 FS/HS
  • Sensor Supported: 0.3MP ~ 8MP (IMX179, OV5640/5648, IMX291, IMX322/323, OV2710, AR0130/0330, MT9P001, MT9J003 etc)
  • Standard Lens options: 2.8mm ~ 25mm, 180,220 degree fisheye
  • Frame rate: 15~30fps at MJPEG/H.264, 2~30fps at YUV format
  • Board Size: 40mm x 40mm
0
Your Cart is empty!
Browse Products
