[Discontinued] OV9782 Global Shutter Color 1MP Wide Angle Camera Module for DepthAI OAK
[Discontinued] USB2 Camera Shield - Support both MIPI and Parallel Interface Sensors
[Discontinued] 12MP IMX378 Wide Angle Camera Module for Raspberry Pi
B0406
Discontinued, check alternative item B0303R.
  • High Quality: 12MP
  • Wide Angle: 120° (DFoV)
  • Mini Size: 24x25mm, V1/V2 size
  • Easy to use: compatible with all Raspberry Pi boards
$45.99
Based on Sony’s IMX378 high-quality image sensor, Arducam IMX378 camera module is a ready-to-use embedded vision solution for the Raspberry Pi family. With a resolution of 12.3MP, a wider angle lens, and a V2-like form factor, it is compatible with any existing Pi models and works with the latest software from the foundation. It can be widely used in machine vision systems and outdoor applications.
Sensor IMX378
Optical Size Type 1/2.3''
Pixel Size 1.55μm×1.55μm (Diagonal 7.857 mm)
Shutter Type Rolling Shutter
Max Sensor Resolution 4056 x 3040
Color Filter Array Bayer RGB
Resolution and Frame Rate RAW10: 1332x990@120fps; RAW12: 2028x1080@50fps, 2028x1520@40fps, 4056x3040@10fps
Supported Platform Pi 4/3/Zero/CM3/CM4
Output RAW10/RAW12
Focus Type Manual
Focus 50cm~INF
Lens f/2.8; EFL: 2.75mm; FoV: 120° (D)
IR Sensitivity Built-in 650nm IR-cut filter, visible light only
Dimensions 25mm × 24mm
Packing Including
  • 1 x IMX378 Camera Module
  • 1 x 150mm 15pin to 22pin flex cable
  • 1 x 80mm 22pin flex cable
