OmniVision's OV9782 is a 1MP (1280x800) global shutter color image sensor. Arducam OV9782 camera module is a color camera option for OAK Series 2 Wide FOV cameras such as OAK-D W, OAK-D W PoE as the 150° DFOV color camera.
It is also compatible with OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P), so you can easily evaluate its sensor and optics performance via a camera board and a flex cable.
Specification
OV9782
Optical Size
Type 1/4''
Pixel Size
3μm×3μm
Global Shutter
Color Filter Array
RGB
Max Sensor Resolution
1280 x 800
Resolution & Frame Rate
1280x800@60fps, 1280x720@60fps, 640x400@120fps
Supported Platform
OAK-D W, OAK-D W PoE, OAK-FFC-3P, OAK-FFC-4P
Output
RAW8/RAW10
Focus Type
Manual
Focus
50cm~INF
f/2.0, EFL: 1.69mm, FoV: 150° (D)
IR Sensitivity
Built-in 650nm IR filter, sensitive to visible light only
1 x OV9782 Wide Angle Camera Module for DepthAI OAK
