Arducam 5MP OV5647 Ultra Wide Angle Fisheye Camera for Raspberry Pi
OV9281 Monochrome Global Shutter 1MP Camera Module for Raspberry Pi
12MP IMX378 Camera Module for Raspberry Pi
B0412
  • High Quality: 12MP
  • Wide Angle: 82.4° (DFoV)
  • Mini Size: 24x25mm, V1/V2 size
  • Easy to use: compatible with all Raspberry Pi boards
$39.99
Based on Sony’s IMX378 high-quality image sensor, Arducam IMX378 camera module is a ready-to-use embedded vision solution for the Raspberry Pi family. With a resolution of 12.3MP and a V2-like form factor, it is compatible with any existing Pi models and works with the latest software from the foundation. It can be widely used in machine vision systems and outdoor applications.
Sensor IMX378
Optical Size Type 1/2.3'' (Diagonal 7.857 mm)
Pixel Size 1.55μm×1.55μm
Shutter Type Rolling Shutter
Max Sensor Resolution 4056 x 3040
Color Filter Array Bayer RGB
Resolution and Frame Rate RAW10: 1332x990@120fps; RAW12: 2028x1080@50fps, 2028x1520@40fps, 4056x3040@10fps
Supported Platform Pi 5/4/3/Zero/CM3/CM4
Output RAW10/RAW12
Focus Type Fixed
Focus Distance 50cm~INF
Lens f/1.8; EFL: 4.74mm ; FoV: 82.4° (D)
IR Sensitivity Built-in 650nm IR-cut filter, visible light only
Dimensions 25mm × 24mm
Raspberry Pi 5 √ √
Packing Including
  • 1 x IMX378 Camera Module
  • 1 x 150mm 15pin to 22pin flex cable
  • 1 x 150mm 22-22pin flex cable
