Arducam 5MP OV5647 Camera Module Motorized IR-CUT Filter for Daylight and Night vision for Raspberry Pi
Arducam 5MP OV5647 Ultra Wide Angle Fisheye Camera for Raspberry Pi
B0428
  • Ultra Wide Angle: A fisheye camera with 220 HFOV for Raspberry Pi. (The lens is LN010)
  • Lens Options: Replaceable M12 lens for your various requirement
  • System Compatibility: Support the lastest Raspberry Pi OS and libcamera apps
$28.99
The Arducam Ultra Wide Angle Camera has a fisheye M12 lens with 220° horizontal field of view which allows you to apply it in various special scenes. The camera is supported by the latest version of Raspberry Pi OS, which supports using libcamera apps to capture images.
  • Cellular phones,PDAs,Toys
  • PC multimedia
  • Wildlife photograph
  • Home security system
  • Digital still cameras,etc.
Sensor Omnivision OV5647 sensor
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Video 1080p 30 fps, 720p 60fps, 480p 90fps
IR Sensitivity Integral IR-cut filter, visible light only
Horizontal Field of View (HFOV) 220°
Effective Focal Length 0.76mm
35mm Equivalent Focal Length 8.2mm
Focus Type Manual
Dimension 36mm x 36mm
Peak Current 300mA
  • 1 x OV5647 Camera Board with M12 M32076M20 Fisheye Lens
  • 1 x 15cm 15-15pin FPC cable
  • 1 x 15cm 15-22pin FPC cable
  • The camera lens is LN010, for more M12 lens options, pelase refer to: LK001
    Raspberry Pi 5 √ √
Used On Pi- Arducam 5MP OV5647 Standrad camera
Datasheet
Maunal
https://www.arducam.com/raspberry-pi-camer-module-released/
