8MP IMX219 175 Degree Ultra Wide Angle Raspberry Pi Camera Module, Compatible with Raspberry Pi 5, 4B, Pi 3/3B+, and Pi Zero 2W
Arducam 8MP IMX219 Autofocus USB2.0 Camera Module with 300mm Extension Cable
IMX219 Raspberry Pi Camera Module with ABS Case, 1080P IMX219 Camera Module Compatible with Raspberry Pi 4 Model B, Pi 3/3B+, and Pi Zero 2W (24*25mm)-Arducam
B039001
  • [2-lane/4-lane Support]Adopt MIPI CSI-2 interface, supporting 2lane/4lane output configurations.
  • Native to Raspberry Pi: No need to install additional driver for this camera.
  • ABS Case: The ABS Case is in the camera package
  • Easy to Steup: You can install on any 1/4 hole distance tripod easily
  • Wide Applications: Not only for beginners, but for advanced gamers, it offers more to explore
was $21.99 Special Price $12.99
No less than the Raspberry Pi official camera V2, this camera module is also equipped with a high-definition IMX219 8MP sensor for shooting HD video and still images. It is excellent in image quality, color fidelity, and low light.
For beginners, this is a very easy camera module to get started; for advanced players, this camera module has more knowledge that you should explore and DIY.
  • Unmanned Aerial Vehicles (UAVs)
  • Building Drones
  • Autonomous Robotic Systems
  • Mobile Medical Imaging
  • Intelligent Video Analytics (IVA)
  • High-Speed Data Interface: Standard 2-lane MIPI CSI-2 interface with configurable 4-lane high-performance mode. Delivers maximum bandwidth for high-resolution sensor data transmission while maintaining compatibility with mainstream embedded platforms.
  • 8MP HD Camera: Designed for Raspberry Pi, based on Sony 8MP IMX219 Sensor.
  • Higher quality: Compared with the official Raspberry Pi Camera v1, not only the resolution is improved, but its image quality, color fidelity, and low light performance are all upgraded by leap.
  • 1080P High resolution: Supports 3280 × 2464 pixel still images, and still captures.
  • Easy to setup: Simply use the 15pin ribbon cable to attach the CSI port on the Raspberry Pi, then make a simple configuration and you are ready to use the camera.
  • Easy to use for beginners, and for advanced gamers, it offers more to explore.
  • Wide Application: Perfect for time-lapse, slow motion, home security applications, monitoring Octoprint 3D Printer, and wildlife camera trap applications.
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 3.04mm
F.NO F2.0
Lens Type Stock Lens
Electrical & Mechanical
Interface MIPI CSI-2
Data Lanes 2-lane (default), configurable to 4-lane
Camera Board Size 25 × 24mm
Peaking Current 300mA
  • 1× Arducam IMX219 Camera Module With Case
  • 1× 15cm 22-22pin FPC Cable
  • 1× 15cm 15-22pin FFC Cable
Raspberry Pi 5 √ √
Documentations
