IMX219 Raspberry Pi Camera Module with ABS Case, 1080P IMX219 Camera Module Compatible with Raspberry Pi 4 Model B, Pi 3/3B+, and Pi Zero 2W (24*25mm)-Arducam
Arducam IMX219 Camera Module with fisheye lens, drop in replacement for Raspberry Pi V2 and Nvidia Jetson Camera
Arducam 8MP IMX219 Autofocus USB2.0 Camera Module with 300mm Extension Cable
B0321
  • More than HD: This camera adopts 8MP IMX219 sensor for sharp image and accurate color reproduction, Max. still resolution 3264H x 2448V.
  • Autofocus: Shoot objects in millimeter level and in the distance on the same camera, automatically controlled without lens adjustment tool, closer and easier than the fixed focus camera.
  • Frame Rates: TBD
  • Plug&Play: UVC-compliant, just connect the camera to PC, laptop, Android device or Raspberry Pi with the included USB cable without extra drivers to be installed.
  • Applications: This small 38mmx38mm camera board is highly recommended for a home surveillance system, monitoring 3D Printer, object recognition and tracking, or other machine vision application.
  • Note: By default, the examples reset the focus as you quit the program or power off. To fix the focus, please alter the example code on your own.
$47.99
Arducam B0321 is a new member of the Arducam's USB camera family. It's an 8MP, based on the 1/4" IMX219 image sensor, UVC compliant, autofocus USB 2.0 camera.
This 8MP IMX219 high resolution color COMS sensor and the autofocus feature make it can be widely used in the home surveillance system, monitoring 3D Printer, object recognition and tracking, or other machine vision application.
Sensor IMX219
Still Resolution 8 Megapixels
Optical Size 1/4"
Output Format MJPG/YUY2
Pixel Size 1.12μm*1.12μm
Sensor Active Area 3280(H)×2464(V)
Max Frame Rate MJPG: 15fps@3264×2448/2592×1944; 30fps @1920×1080/1600×1200/1280×720/800×600/640×480
YUV: 10fps@1280×720/800×600/640×480/320×240
Focus Type Auto Focus
FOV 78°(D)×60°(H)×47°(V)
Lens Type Stock Lens
F.NO F2.0
E.F.L 2.96mm
Default Focus Range 10cm-∞
Interface USB 2.0 device
Connector B4B-ZR(LF)(SN)
Working Current Max 200mA
Camera Board Size 38×38 mm/28x28 mm with Case
Audio Dual Microphone
Supported OS Windows, Linux, Android, and Mac OS with USB Application
Recommend Sample Application Amcap for Windows, VLC Player for Linux
UVC Controls Saturation, Contrast, Acutance, White balance, Exposure.
UVC Camera Module
  • 1pcs Arducam IMX219 USB2.0 Camera Module
  • 1pcs Arducam 300mm Extension Cable
  • 1pcs 3.3ft (1M) USB cable
