Arducam for Raspberry Pi Camera, 8MP IMX219 Auto Focus Camera Module with Motorized Lens, Software Precise Manual Focus for Raspberry Pi 4B/3B+, Zero, Zero 2w
IMX219 Raspberry Pi Camera Module with ABS Case, 1080P IMX219 Camera Module Compatible with Raspberry Pi 4 Model B, Pi 3/3B+, and Pi Zero 2W (24*25mm)-Arducam
8MP IMX219 175 Degree Ultra Wide Angle Raspberry Pi Camera Module, Compatible with Raspberry Pi 5, 4B, Pi 3/3B+, and Pi Zero 2W
B0392
  • [2-lane/4-lane Support]Adopt MIPI CSI-2 interface, supporting 2lane/4lane output configurations.
  • Wide Applications: The Wide Angle Camera can be used in various field such as Machine vision, time-laspe, field photograph and so on
  • Wide Angle: Attached with a Wide Angle M12 lens(175(D) x 155(H) x 115(V))
  • Replaceable Lens: The lens can be replaced according to your various requirement, please refer to LK001 for more options
was $29.99 Special Price $19.99
No less than the Raspberry Pi official camera V2, this camera module is also equipped with a high-definition IMX219 8MP sensor for shooting HD video and still images. It is excellent in image quality, color fidelity, and low light.
This camera module has a 175°(D) wide-angle M12 Lens, which provides a much wider Field of View compared to the stock lens on V2 camera module.
For beginners, this is a very easy camera module to get started; for advanced players, this camera module has more knowledge that you should explore and DIY.
  • Astrophotography
  • Surveillance cameras
  • FA cameras
  • High-Speed Data Interface: Standard 2-lane MIPI CSI-2 interface with configurable 4-lane high-performance mode. Delivers maximum bandwidth for high-resolution sensor data transmission while maintaining compatibility with mainstream embedded platforms.
  • Raspberry Pi Camera: Designed for Raspberry Pi, this 8MP HD camera module has a Sony IMX219 8MP pixel sensor with a wide-angle M12 lens.
  • 8MP More than HD: Supports 3280 × 2464 pixel still images, and still captures. The Raspberry Pi Camera Board v2 – 8 Megapixels is a leap forward in image quality, color fidelity, and low light over the camera v1.
  • Wide Compatibility: The camera is not only compatible with all models of Raspberry Pi 1, 2, 3 and 4, but also with Raspberry Pi Zero and Zero 2W, which can be easily used with a simple configuration.
  • Easy to Setup: The package comes with a 15cm and 50cm 15pin FPC cable, and a 15cm yellow 15-22pin FPC cable for Raspberry Pi Zero and Zero 2W. Simply connect the Raspberry Pi board and camera with the FPC cable and you can easily use this 8MP high-quality camera.
  • Application: Easy to use for beginners, and for advanced gamers, it offers more to explore. Perfect for time-lapse, slow motion, home security applications, monitoring Octoprint 3D Printer, and wildlife camera trap applications.
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 1.3mm
F.NO F2.0
Field of View(FOV) 155°(H)×115°(V)×175°(D)
Electrical & Mechanical
Interface MIPI CSI-2
Data Lanes 2-lane (default), configurable to 4-lane
Camera Board Size 25 x 24mm
Peaking Current 300mA
  • 1 x 8MP IMX219 Camera Module with Wide Angle M12 Lens
  • 1 x  15cm 15-22pin FPC cable
  • 1 x 15cm 22-22pin FFC cable
    Note for Supported Raspberry Pi Boards and OS
    Platform Bookworm(rpicam) Bullseye(libcamera) Buster(raspistill)
    Raspberry Pi 5 √
    Raspberry Pi 4B / 3B+ / 3A+ / Zero / Zero 2 W √ √
