Stereo Camera HAT
Stereo Vision for Every Pi
Proprietary ArduChip to disguise the dual-cam setup as a natively supported camera module, and endow the only camera port with more possibilities
Rethink the possibilities of Pi cameras
Innovative. Revolutionary.
Dual Cam, Full Sync
It allows you to connect two 5MP OV5647 or two 8MP IMX219 Pi cameras to a single standard Pi board and takes images or videos at the same time. More importantly, this binocular solution makes both cameras fully synchronized.
It supports and is fully compatible with Raspistill commands for preview, and Raspivid command for video capture/processing with RPi’s default camera driver for its 5MP and 8MP cameras.
Learn More in the Blogs
Generate Depth Map on Every Raspberry Pi Model Easily with Arducam Stereo Camera HAT and OpenCV, No Compute Module Needed
Most creatures have evolved to see the world with two eyes, but most of the Rasberry Pi models have not – the standard Raspberry Pi only comes with a single camera port. Hard as we try, the multi-camera and stereo vision applications on a Raspberry Pi did not deliver a smooth experience, until Arducam introduced […]
Buy Arducam Stereo Camera HAT
You can get the stereo camera HAT alone and solder your Pi camera modules as told in the instruction, but we would recommend you to go with Arducam 5MP or 8MP stereo camera HAT bundle kits.
