Raspberry Pi’s new camera module v3 is finally out.
It’s got a fairly competent sensor, the long-awaited autofocus, and also comes at pretty unbeatable prices, just like its predecessors.
However, is it as perfect as it appears? Can you use it as an all-rounder for all your projects?
Before you decide it’s a 10/10 and crown it the best RPi camera module of all time, let’s take a deeper look.
Camera Module V3 in a Nutshell
official camera module 3 sensor and variants
Camera module 3’s sensor, price, and versions.
To give you a quick grip, here’s the gist of the new CM v3 series:
  • The V3 cameras offer 4 variants: Standard, Wide, NoIR, and NoIR Wide.
  • The entire v3 line is based on the 12MP Sony IMX708 CMOS sensor. According to Eben, they picked this sensor years ago.
  • IMX708 is a rolling shutter sensor, which means all V3 cameras have rolling shutters.
  • All V3 cameras have autofocus.
  • For $25, you can get the Standard & NoIR variant, and the Wide and NoIR Wide are available at $35.
  • The autofocus is achieved by a mixture of PDAF and CDAF.
  • FoV for both V3 Standard and V3 NoIR comes at 66° (horizontal), yet for the two wide versions, it’s 102° (horizontal).
  • They have a 5cm MOD (minimum focus distance) for both Standard and NoIR, and 10cm for Wide & NoIR Wide.
  • 4608 x 2592 is the highest resolution you can get for still images, 1080p50 max for video.
  • All cameras support capturing in HDR.
  • All 4 cameras have the same board size as V1.3 and V2 cameras.
  • The v3 line works with all Raspberry Pi models, except for Raspberry Pi 400.
  • To use the V3 cameras with Pi zero models, you need additional camera cables.
  • All V3 cameras are compatible with both libcamera & Picamera2, but they no longer work with legacy software (raspivid, raspistill, etc.).
  • The camera module v3 line will stay in production for at least 7 years (until Jan. 2030).
You can find sample photos from Camera Module 3’s official page (scroll to the bottom), Les pounder’s review article, and Jeff Geerling’s hands-on video.
Camera Module 3 Has Got the Same 2-Lane MIPI Connection
CM3 only got 2 lane MIPI connection
2-lane MIPI may be enough for Pi, but not for other dev boards.
All official camera modules (V1.3/V2/HQ), including the v3 series, only offer 2-lane MIPI connections.
The transferring rate (around 2 Gbps) of a 2-lane connection and the processing power of the latest Pi models are sufficient enough for the v3 cameras, but if you use them with a non-RPi board that offers 2+ MIPI lanes, the bandwidth cap can be a huge disadvantage.
With HDR, You Only Got a Quarter of the Resolution
when in HDR mode you can only get 3MP max
Max resolution for HDR mode: 2304 x 1296.
You can use the new v3 camera to capture both HDR images and videos, and in HDR mode, the sensor achieves High Dynamic Range by doing pixel synthesis where 4 pixels on the same channel (R, G, or B) with different exposures (in the IMX708 case, long, middle and short exposures) are combined into a large one after the readout.
Kinda like this:
quad bayer HDR synthesis
How Camera Module 3’s HDR works
Since the IMX708 is a quad Bayer sensor, its HDR output is limited to 3MP. This is also confirmed by David Plowman, one of the main engineers behind these V3 modules.
From some of the sample photos taken by the foundation, and Les Pounder (Tom’s Hardware), you can tell that the HDR images are more vibrant and preserve more details in both the shadows and highlights.
With the latest software, it’s super easy to capture HDR videos with the new V3 cameras, this can come in really handy for scenes with bright highlights and dark shadows.
NoIR & NoIR Wide: Things to Always Keep in Mind
1. Additional IR LEDs are required
extra LEDs are needed if you want for NoIR versions
IR LED is a must-have for the NoIR versions.
Both NoIR and NoIR Wide have only a camera module and a 15-pin ribbon cable in the box.
If you tend to use the NoIR variants in dark environments or for night vision applications, external illumination is needed (preferably 850nm/950nm IR LEDs).
2. Infrared pollution in broad daylight
NoIR camera module with various optical filters
Taken with the 16MP-NoIR, the image on the upper left is what you will get.
Without the IR cut filter, the IMX708 sensor is capable of capturing a wider wavelength range than the standard versions.
If you use them in environments that have strong sunlight, the final image/video you get may appear with a reddish tint (caused by Infrared).
3. Switchable IR-Cut is achievable
switchable IR cut is the ultimate solution for the NoIR pi cameras
Switchable IR-Cut filter saves the day (no pun intended).
A motorized IR-Cut filter, a light sensor, and IR LEDs are some of the popular fixes we did with the previous NoIR Pi cameras.
The onboard light sensor controls when the IR-Cut filter and IR LEDs should be turned on/off, the IR-cut filter is switched on throughout the day and automatically goes off at night with the LEDs on.
This makes it possible for the NoIR version to work 24×7 with perfect captures under daylight and great night vision abilities in the dark.
We are pretty confident about applying the same fixes to the two V3 NoIR cameras.
Using Camera Module V3 on Nvidia Jetson Boards?
supporting camera module 3 to the Nvidia Jetson boards
Sooner or later, we are going to see V3 cameras running on Jetson boards.
There have been no official support or statements about adding such support from both Raspberry Pi and Nvidia, but we’ve always been on the front lines of getting RPi native cameras to Nvidia Jetson boards, and our 16MP-AF series and the 64MP-AF are available too.
The V3 camera series would be a great addition and offer immeasurable value to the Jetson ecosystem, and on that note, it’s only a matter of time.
Unavoidable Drawbacks of Autofocus for Certain Types of Applications
fuzzy images taken with autofocus camera module on a drone
Unless you have proper stabilization in place, you will have super blurry images/videos with drones.
Under certain circumstances, autofocus can actually be trouble.
The tiny focus motor in the lens works perfectly great when the camera module is positioned in an immobile fashion, but if you were to use it for UAV, or robot-related projects where there could be environmental disturbances, any sort of quivering and vibration would greatly mess up the results for you.
Compatibility with V1/V2 Camera Cases
best enclosure with mounts for Raspberry Pi camera module 3
Mounting the camera is another big problem for many.
Due to the bulky lens design, the V3 camera can not fit into the official Pi zero case, and neither will it work with most of the popular cases made for V1 and V2 cameras.
Since the V3 camera series has a similar lens layout as our 16MP-AF and 64MP-AF, and with the same mounting holes, the camera cases we created for them can seamlessly house the V3 cameras!
Kevin McAleer has also made another cool 3D-printed Giraffe camera mount for it.
Accessories: Extension Cable, Multiplexing, Pan-Tilt Bracket, etc.
there are lots of accesories you can get for the camera module 3
Can I use super-long cables?
How about getting multiple V3 cameras to stream or capture on a Raspberry Pi 4?
What if I want to put the camera modules underwater?
Are there other ways to increase the FoV?
Is it too much if I want to turn them into USB cameras?
What about exchangeable lenses?
The same questions being asked for old Pi cameras will eventually come up on the V3 series, but as a matter of fact, there has always been only one single request: how can we get more out of the V3 camera modules?
Luckily, we are better prepared this time.
The Conclusion: Camera Module 3 Sets a New Paradigm for RPi Cameras
a timeline of Raspberry Pi Cameras 1
A timeline of Raspberry Pi cameras.
It’s encouraging to witness how the foundation evolves with its community in certain forms.
Raspberry Pi sure did a great job with the V3 cameras: a modern sensor, HDR, and incredibly amazing PDAF (Phase Detection Autofocus) along with A+ software support.
With the V3 series taking the lead, It’ll be another great year with more and better camera innovations.
Footnote
  • Images by John Lee, our Chief Design Officer.
