[Discontinued] Arducam MINI IMX477 for Raspberry Pi CM, CM3, CM3+, CM4
Discontinued, check alternative item B0262
Notify Me
SKU: B0271 Category:
To make High Quality camera module work on applications with size and weight limits, Arducam just released this small size camera module for Raspberry Pi CM, CM3, CM3+, CM4. It is fully compatible with Raspberry Pi V2 module size, a 24mm x 25mm IMX477 camera board, a low distortion M12 mount lens.
Important Note on the IMX477 MIPI lanes
Our IMX477 camera module support 4-lane in hardware, but the 4-lane camera driver requires extra customization. Here is why:
  1. Standard Raspberry Pi and Jetson Nano/Xavier NX can’t physically support a 4-lane connection (both of them only have 2-lane CSI connectors). Only the Raspberry Pi Compute Module and some 3rd party Jetson Carrier Boards come with 4-lane hardware support. Therefore, it’s not a general need.
  2. Extra works, specifically camera drivers, are required for a 4-lane connection other than the 4-lane physical connector. And the drivers are limited by the performances of the platform itself. For example, 4-lane can’t unlock 4k video on Raspberry Pi because the VideoCore does not currently support it. Jetson Nano is also to some extent limited because of the encoding capabilities. You need to make sure you really need it.
Specs
– Sensor: IMX477
– Optical Format: 1/2.3″ (diagonal 7.857mm)
– Resolution: 4056(H) x 3040(V) 12.3MP
– Pixel Size: 1.55um x 1.55um
– IR Sensitivity: Visible light
– Interface: 2-lane MIPI CSI-2
– Default Lens Mount: M12 Mount(SKU:LN053)
– Frame Rate: 1080p30, 720p60 and 640 × 480p60/90
– Format: 1/2.3 inch
– Focal Length: 3.9mm
– Aperture (F): F2.8
– Field of View (FOV): 75° (H)
– Mount: M12 Mount
– Back Focal Length: 4.49mm
– MOD: 0.1m Dimension: Φ14×18.67mm
—Weight: 5g
Camera board
– Board Size: 24mm×25mm
Lens Options
LN059
LN036
LN058
LN024
LN053
LN033
LN069
LN064
LN056LN031LN074
Part No:
M17350H08
M2025ZM02
M231250H03
M2306ZM13
M23390H08
M23356H09
M23270H10
M23325H12
M23272M14
M25156H18
M27150H19
Optical Format1/2.3'1/2.3'1/2.3''1/2.3''1/2.3''1/2.3''1/2.3''1/2.3''1/2.3''1/2.3'1/2.3'
EFL(mm)35.0025.00 12.506.003.903.562.703.252.271.561.50
BFL(mm)5.505.20 2.117.564.495.924.974.103.014.305.19
Construction5G6G 6G+IR6G+IR6G+IR4G3P+IR5G2P+IR7G+IR8G+IR6G+IR9G+IR
F/NO3.02.0 2.352.02.82.52.82.22.52.01.8
HFOV on 1/2.3‘’ Cam20°30°50°75°90°100°120°140°180°190°
IR filterNo IR filterNo IR filter 650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter
MOD0.35m0.20m 0.30m0.30m0.30m0.20m0.30m0.30m0.20m0.20m0.30m
Size(mm)
22x 29.317 x 21 14 x 22.7216x 16.4114x 18.6714x 16.316x 18.4317x 1917.2x 2220x 17.324x 16.9
NOTE: The M12 Lens kit for the HQ/AR1820HS Camera module, please check LK003, 6 lenses are included.
NOTE: For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses on the Camera board.
1 pcs 12.3MP IMX477 color camera module
1 pcs 3.9mm focal length M12 mount camera lens
1 pcs 300mm 22pin camera cable
MIPI
IR sensitivity
Visible Light
