Arducam Complete High Quality Camera Bundle for Jetson Nano, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS-Mount Lens, Jetvariety Adapter Board, Metal Enclosure, Tripod and HDMI Extension Adapter
Note: This product was discontinued. Please check the upgrade version-SKU: B0250
  • Work Natively with Jetson Nano. Driver: https://github.com/ArduCAM/MIPI_Camera/tree/master/Jetson/IMX477/driver
  • Get Clearer Images: This camera adopts 1/2.3″ 12.3 Megapixel IMX477 sensor for sharp image, max. still resolution 4056(H) x 3040(V).
  • No Hassle: No more wasting time looking for the CS lens and camera case. It includes A 1/2.3″ 6mm focal length CS lens, and an industrial metal enclosure mounted on the camera board, the bundle also comes with a Jetvariety adapter board, mini tripod stand and a set HDMI extension adapter.
  • More Lanes: The Arducam high quality camera module has a 4-lane MIPI CSI-2 interface, more than the official one, makes it possible to get more data through.
  • Support More Platforms: It supports all Jetson Nano A02&B01 models. For Raspberry Pi models (Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero, and more), you need to remove the Jetvariety adapter board and connect the camera cable to Raspberry Pi (camera cable included). For PC/laptop, you need a camera shield and a MIPI adapter board, please search for USB2 camera shield B0175 or USB3 camera shield B0111, and MIPI adapter board B0123.
SKU: B0243 Categories: , ,
The official Pi HQ camera is only available in one model. It doesn’t include a lens and a case, and only comes with limited recommendations. To solve these pain points and implement the applications on Jetson Naon, Arducam released this complete camera bundle, an IMX477 camera board with a 6mm CS lens, a customized metal enclosure, a Jetson Nano adapter board, a tripod stand and a set extension adapter. This camera module supports Jetson Nano as well as all Raspberry Pi models and PC/laptop (need MIPI adapter board and USB camera shield, not included).
IMPORTANT NOTE ON THE IMX477 MIPI LANES
Specs
  • Camera
- Sensor: IMX477 - Optical Format: 1/2.3" (diagonal 7.857mm) - Resolution: 4056(H) x 3040(V) 12.3MP - Pixel Size: 1.55um x 1.55um - IR Sensitivity: Visible light - Interface: 4-lane MIPI CSI-2 - Default Lens Mount: CS-Mount - Frame Rate: (depends on the target platform, maximum fps limit might apply) 1920x1080 @ 60fps 4032x3040 @ 30fps
  • Lens
- Format: 1/2.3 inch - Focal Length: 6mm - Aperture (F): Max. F1.2 - Field of View (FOV): 65° (H) - Mount: CS-Mount - Back Focal Length: 7.53mm - MOD: 0.2m - Dimension: Φ30×31mm - Weight: 53g
  • 1 pcs complete 12.3MP IMX477 color camera mounted in a metal encolsure
  • 1 pcs 1/2.3 inch 6mm focal length CS-mount lens and
  • 1 pcs HDMI-CSI camera adapter board with 60mm/2.36inch 15 pin camera cable
  • 1 pcs Jetvariety adapter board
  • 1 pcs 1m high-speed HDMI cable
  • 1 pcs mini tripod stand
  • 1 pcs 150mm/6inch 15 pin camera cable
  • 1 pcs 73mm/2.9inch 15 pin to 22 pin camera cable for Raspberry Pi Zero&W
