Arducam 2MP MIPI Camera Module with AR0230 OBISP for Jetson Nano
Arducam Complete High Quality Camera Bundle for Jetson Nano, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS-Mount Lens, Jetvariety Adapter Board, Metal Enclosure, Tripod and HDMI Extension Adapter
Arducam 8MP Varifocal USB Camera Module, 4K CMOS IMX179 UVC Webcam Board with 2.8-12mm Zomm Lens, 6.56ft/2m Cable for Windows, Linux, Android and Mac OS
UB0226
Discontinued, please check the 12MP version SKU:B0288
More than HD: This camera adopts 8MP IMX179 sensor for sharp image and accurate color reproduction
Wider Angle of View: Rotate the zoom ring, focus ring and aperture ring to get a clear image in different focus distance with a field of view 86°-28°.
High Frame Rates: MJPG 15fps@3264 x 2448; 30fps@1920 x 1080; YUY2 30fps@640 x 480
Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
Applications: Widely used for the video surveillance system, live streaming, record lesson and conference, and other vision applications.
Arducam has been a professional designer and manufacturer of SPI, MIPI, DVP and USB cameras since 2012. We also offer customized turnkey design and manufacturing solution services for customers who want their products to be unique.
Arducam UB0226 is a new member of the Arducam's USB camera family. It's an 8MP, based on the 1/3.2" Sony IMX179 image sensor, UVC compliant, 5-50mm varifocal USB 2.0 camera with the metal shell.
Applications:
Video conference
Live streaming
Record lesson and conference
Features & Specs
Sensor: 1/3.2” IMX179
Resolution: 8MP 1920 x 1080
Data Format: H.264/MJPG/YUY2
Frame Rate: MJPG 15fps@3264 x 2448; 30fps@1920 x 1080; YUY2 30fps@640 x 480
Resolution: 8MP 3264H x 2448V
Frame rate: MJPG 15fps@3264x 2448; MJPG 30fps@1920 x 1080; YUY2 30fps@640 x 360.
Field of View (FOV): 86°-28°
Lens Mount: CS
Focal Length: 2.8-12mm
IR Sensitivity: Integral IR filter, visible light only
Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
System Compatibility: Windows, Linux, Mac, and Android with UVC
Power
Power Supply: USB powered 5V
Working Current: MAX 500mA
Physical
Operating Temp.: -4°F~158°F (-20°C~+70°C).
Dimension: 50mmx50mmx89mm
Cable Length: default 6.56ft (2M)
1 × 8MP IMX179 2.8-12mm varifocal USB 2.0 camera with full metal shell
1 × 6.56ft (2M) USB 2.0 cable
