[Discontinued] Arducam 1/4
[Discontinued] Arducam 1/4" M12 Mount 1.05mm Focal Length Fisheye Camera lens M40105M19
Arducam ESP32 UNO Board for Arducam Mini Camera Module Compatible with Arduino UNO R3
[Discontinued] 1080P Day & Night Vision USB Camera Module, 2MP Automatic IR-Cut Switching All-Day Image USB2.0 Webcam with IR LEDs
B0205
Discontinued, check alternative item B0506
  • Day/Night Vision: IR-CUT Filter switched in and out automatically based on light condition (only visible light during the daylight and infrared sensitivity during the night with 850 IR LEDs on)
  • HD Resolution: This camera adopts 2MP OV2710 sensor for sharp image, Max. resolution: 1920*1080
  • High Frame Rates: MJPG 30fps@1080P; YUY2 30fps@640x 480; High speed USB 2.0 interface.
  • Plug&Play: UVC-compliant, just connect the camera to PC, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: this mini 38mmx38mm camera board can be installed in most hidden and narrow position for a home surveillance system, wildlife photography, dashcam, baby camera, etc.
$34.99
The B0205 is a new member of Arducam’s USB camera family. Based on 1/2.7” OV2710, it's a 2MP, UVC-compliant, wide-angle USB 2.0 camera with a motorized IR-Cut filter and infrared LEDs. The motorized (switchable) IR-CUT filter and infrared LEDs can be triggered by the photoresistor according to the light environment to be ON/OFF to block or pass the infrared light. It can be widely used in wildlife photography, home security systems, baby cameras, etc.
Applications:
  • Video conference
  • Day&night vision security camera system
  • Dash camera
  • Monitoring 3D printer
  • Baby Camera
  • Robot and machine vision
Features & Specs
  • Sensor: 1/2.7” OV2710
  • Resolution: 2MP 1920 x 1080
  • Data Format: MJPG/YUY2
  • Frame Rate: MJPG 30fps@1920 x 1080; YUY2 30fps@640 x 480.
  • connector: SWR201-NRTN-S04-RL-WH
  • IR Sensitivity: Integral IR filter, switch automatically based on light conditions (only visible light during the daylight and IR sensitivity during the night
  • Field of View (FOV): H= 100°, D=138°
  • Lens Mount: M12
  • Focusing Range: 3.3ft (1M) to infinity
  • Auto Control: Saturation, Contrast, Acutance, White balance, Exposure.
  • System Compatibility: Windows, Linux, Mac, and Android with UVC.
Power
  • Power Supply: USB powered 5V
  • Working Current: MAX 500mA
Physical
  • Operating Temp.: -4°F~158°F (-20°C~+70°C).
  • Dimension: 38mmx38mm
  • Cable Length: 3.3ft (1M)
  • Connector No: S4B-ZR(LF)(SN)
Lens option
SKU LN065 LN005 LN055 LN007
Model No: M2512ZH03 M27210H08 M27195H15 M25170H12
Optical Format 1/2.5'' 1/2.7'' 1/2.7'' 1/2.5''
EFL(mm) 12 2.1 1.95 1.7
BFL(mm) 6.5 6.3 3.8 4.7
Construction 6G+IR 6G+IR 6G+IR 6G+IR
F/NO 2.0 2.0 2.0 2.0
FOV (D/H/V) on 1/2.7‘’ Cam 31/27/15 136/130/101 158/155/136 180/180/180
FOV (D/H/V) on 1/2.8‘’ Cam 29/25/14 131/125/94 154/150/129 180/180/180
FOV (D/H/V) on 1/2.9‘’ Cam 26/23/13 127/120/89 149/145/121 180/180/180
IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter
MOD 0.3m 0.3m 0.2m 0.2m
Size(mm) 14 x 16.7 14 x 15.2 17.5 x 19.9 20 x 18.7
3D drawing.step
  • 1 × 2MP OV2710 USB 2.0 camera board
