This Arducam IMX219 camera module is designed mainly for Raspberry Pi V2 camera board and NVIDIA Jetson Board, replacing the default standard IMX219 camera module with the auto focus one. It can be used for drones, robots, action camera,s and 3D scanning applications. The highlight of this camera is that the lens focus is programmable by software, and Arducam team provides an open-source code to implement software auto-focus function for Jetson Board.
| Image Sensor | IMX219 |
| Still Resolution | 8 Megapixels |
| Video Modes | 1080p47, 1640 × 1232p41 and 640 × 480p206 |
| Sensor Resolution | 3280 × 2464 pixels |
| Sensor image area | 3.68 x 2.76 mm (4.6 mm diagonal) |
| Pixel Size | 1.12 µm x 1.12 µm |
| Optical Size | 1/4" |
| IR Sensitivity | without IR-cut filter, sensitive to IR light |
| Focus Type | Programmable/Auto Focus |
| Focal Length | 2.8mm |
| F.NO | F2.2 |
| Field of View(FOV) | 65°(H)×51°(V)×77.6°(D) |
| Lens Type | Stock Lens |
| Focus Distance | 80mm to infinity |
| Peaking Current | 300mA |
