Arducam 8MP Pan Tilt Zoom PTZ Camera for Raspberry Pi 4/3B+/3 and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam PTZ Pan Tilt Zoom Camera Controller for Raspberry Pi 5/4/3B+/3 - Sensor/Camera Board NOT Included
Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera for Raspberry Pi 5/4/3B+/3
B01675MP
  • Real PTZ with servos for directional control and varifocal lens for optical zoom now comes to the Raspberry Pi
  • Switchable IR Cut: Through software for your day/night vision
  • Fully use CSI connector: Now that a single camera can be used to monitor places that should be covered by multiple ones
  • Autofocus control: pan/tilt/zoom keyboard control supported in software
  • PTZ Controller Board Connector Part Number: S6B-XH-A-1
$69.99
PTZ is an abbreviation for pan, tilt, and zoom and reflects the movement options of the camera, and a pan–tilt–zoom camera (PTZ camera) is a camera that is capable of remote directional and zoom control. A PTZ camera is not a still camera. Instead, it could move the camera and the lens, and that means a single camera can be used to monitor places that should be covered by multiple ones. You can save a lot of cost and time in purchasing and deploying the camera if a PTZ camera can handle the job. With its moveable lens, you will also be able to zoom the camera to see a specific area that you are interested in. To conclude, it’s “do more with less.”
Application
  • IoT cameras
  • Robot cameras
  • Wildlife cameras
  • Cellular phones,PDAs,Toys
  • Other security and surveillance projects
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Focal-Length 3.2-11.1mm±5%
F No. W:1.6-T:3.3±5%
Focus Type Front group: focus Back group: Zoom
M.O.D 0.8m
Dimension 36mm x 36mm
Pan and Tilt Range 0-180°
Zoom Range (Wide => Tele) 2317 steps 0.00396mm/step
Focus Range(Near => Far) 3009 steps 0.0047mm/step
  • 1 x Arducam PTZ Pan Tilt Zoom Lens, assembled with a 5MP IR-CUT switchable camera board
  • 1 x Controller Board
  • 1 x 15-15 Pin FPC Cable (11.8 in/30 cm)
  • 1 x 15-22 Pin FPC Cable (11.8 in/30 cm)
  • 1 x XH2.54 Jumper wire with 6Pin Female Connector (11.8 in/30 cm)
  • The Raspberry Pi board is not included in the package
  • Please refer to the following documentation to run the camera correctly
    Raspberry Pi 5
Specification
1. 5MP OV5647 / 8MP IMX219 Camera No. Items Specification 1 F No. W:1.6-T:3.3±5% 2 Focal-Length 3.2-11.1mm±5% 3 Optical Back Focal Length 5.8±0.1 4 Mechanical Back Focal Length 13.45±0.2 5 TTL 52.14±0.2 6 Image Circle ∅6.9 7 Lens Structure 6G3P 8 Mount ∅14 9 FOV 1/2.7”(16:9): H(113~30),V(60~16),D(137~34) 1/3”(4:3): H(91~25),V(66~18),D(120~30) 1/4”(4:3): H(67~18),V(49~13),D(90~22) 10 M.O.D 0.8m 11 […]
5MP OV5647 PT&PTZ Camera Module
Introduction Arducam PT camera can move in two dimensions with 180 degrees horizontal and 145 degrees vertical movements. So it can be used to monitor places that should be covered by multiple ones commonly in the surveillance system. Arducam PTZ cameras are the complete solution to turn your Raspberry Pi cameras into a fully functional […]
ptz-pan-tilt-zoon-camera-on-raspberry-pi-arducam-blog-thumbnail
Pan/Tilt/Zoom (PTZ) Camera Is Finally Coming to The Raspberry Pi Thanks to Arducam
We all know that there is a CSI connector on the Raspberry Pi to facilitate the connections of a small camera to the processor, but how should we facilitate the small camera itself? As a professional camera manufacturer and solution provider, Arducam has been obsessed with this question for the last 6 years, and came […]
11 comments
Selection Guide
Edit
