Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera for Raspberry Pi 5/4/3B+/3
Arducam PTZ Pan Tilt Zoom Camera Controller for Raspberry Pi 5/4/3B+/3 - Sensor/Camera Board NOT Included
B0167
  • Real PTZ with servos for directional control and varifocal lens for optical zoom now comes to the Raspberry Pi
  • Switchable IR Cut through software for your day/night vision
  • Make full use of the CSI connector now that a single camera can be used to monitor places that should be covered by multiple ones
  • Autofocus control, pan/tilt/zoom keyboard control supported in software
$49.99
PTZ is an abbreviation for pan, tilt, and zoom and reflects the movement options of the camera, and a pan–tilt–zoom camera (PTZ camera) is a camera that is capable of remote directional and zoom control.
A PTZ camera is not a still camera. Instead, it could move the camera and the lens, and that means a single camera can be used to monitor places that should be covered by multiple ones. You can save a lot of cost and time in purchasing and deploying the camera if a PTZ camera can handle the job. With its moveable lens, you will also be able to zoom the camera to see a specific area that you are interested in. To conclude, it’s “do more with less.”
  • IoT cameras
  • Robot cameras
  • Wildlife cameras
  • Sun Tracker
  • Other security and surveillance projects, etc.
  • 1 x Arducam PTZ Pan Tilt Zoom Lens for Raspberry Pi
  • 1 x Controller Board
  • 1 x 15-Pin FPC Cable (11.8 in/30 cm)
  • 1 x XH2.54 Jumper wire with 6Pin Famale Connector (11.8 in/30 cm)
  • There is no camera or Raspberry Pi board included in the package
  • The size of the Rpi V1&V2 camera board is not compatible with the size of zoom lens(SKU: B0167), please check the bundle kit(SKU: B01675MP, B01678MP, B016712MP)
    Raspberry Pi 5 √ √
Specification
1. 5MP OV5647 / 8MP IMX219 Camera No. Items Specification 1 F No. W:1.6-T:3.3±5% 2 Focal-Length 3.2-11.1mm±5% 3 Optical Back Focal Length 5.8±0.1 4 Mechanical Back Focal Length 13.45±0.2 5 TTL 52.14±0.2 6 Image Circle ∅6.9 7 Lens Structure 6G3P 8 Mount ∅14 9 FOV 1/2.7”(16:9): H(113~30),V(60~16),D(137~34) 1/3”(4:3): H(91~25),V(66~18),D(120~30) 1/4”(4:3): H(67~18),V(49~13),D(90~22) 10 M.O.D 0.8m 11 […]
PTZ Camera
A Camera That Gives Raspberry Pi Panoramic Vision For years the Raspberry Pi has no decent improvements on their camera performance while there are increasing requirements for different camera solutions on Raspberry Pi. Now Arducam will address these needs and introduce a Pan Tilt and Zoom solution which is commonly used for the surveillance cameras. […]
3D drawing.rar
ptz-pan-tilt-zoon-camera-on-raspberry-pi-arducam-blog-thumbnail
Pan/Tilt/Zoom (PTZ) Camera Is Finally Coming to The Raspberry Pi Thanks to Arducam
We all know that there is a CSI connector on the Raspberry Pi to facilitate the connections of a small camera to the processor, but how should we facilitate the small camera itself? As a professional camera manufacturer and solution provider, Arducam has been obsessed with this question for the last 6 years, and came […]
11 comments
Selection Guide
Edit
