Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera for Raspberry Pi 5/4/3B+/3
Arducam 5MP OV5647 Wide Angle 120°(D) Miniature Camera Module with Flex Cable for Pi Zero, Pi 5 and Pi Compute Module
Arducam 5MP OV5647 Wide Angle 160° Miniature Camera Module with Flex Cable for Pi Zero, Pi 5 and Pi Compute Module
B006605
  • Supports raspberry pi zero only. For Raspberry Pi Model A/B/B+, Raspberry Pi 2/3/3B+, please search “B0066”
  • Sensor: 1/4 inch OV5647 sensor in a fixed-focus lens, angle of view: 160° diagonal
  • Integral IR filter, visible light
  • Still picture resolution: 2592 x 1944, Max video resolution: 1080p
  • Dimension: 60mm × 11.5mm × 9.5mm
$20.99
In order to meet the increasing need of Raspberry Pi Zero compatible camera modules, the Arducam team now released another add-on spy camera module which is fully compatible with Raspberry Pi Zero and Pi compute module.
The board itself is tiny, at around 60mm x 11.5mm. The neck width of the camera module is 6mm, this highlight making it perfect for endoscope, spy surveillance or other applications where size and image quality are important. It connects to Raspberry Pi Zero by way of a short ribbon cable. The camera is connected to the BCM2835 processor on the Pi Zero via the CSI bus, a higher bandwidth link which carries pixel data from the camera back to the processor.
This bus travels along the ribbon cable that attaches the camera board to the Pi. The sensor itself has a native resolution of 5 megapixel, and has a fixed focus lens onboard. In terms of still images, the camera is capable of 2592 x 1944 pixel static images, and also supports 1080p30. 720p60 and 640x480p60/90 video. It attaches to Raspberry Pi Zero by way of the small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras. The CSI bus is capable of extremely high data rates, and it exclusively carries pixel data.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Diagnoal Field of View (DFOV) 160°
Focus Type Manual
Lens Type M7 Lens
Dimension 60mm × 11.5mm x 9.5mm
  • 1pcs Spy Camera Module 1/4 Inch 5 Megapixel Module with flex cable for Raspberry Pi
  • Raspberry Pi Board is Not included in the package
New Low Cost OV5647 Mini Camera Module for Raspberry Pi Now Available
Introduction In order to meet the increasing need of Raspberry Pi compatible camera modules. The ArduCAM team now released ultra low cost add-on mini camera module for Raspberry Pi series boards which is fully compatible with official one.
1 comment
3D drawing.STEP
3D drawing.STEP
Compatibilites
RASPBERRY PI MODEL COMPATIBILITY
ONLY Support Pi Zero
OS COMPATIBILITY
  • Raspbian,
  • MotionEyeOS,
  • OctoPi,
  • Ubuntu,
  • Arch Linux, etc.
EXTENSION CABLE COMPATIBILITY
  • All 15pin Pi cam flex ribbon cables,
  • [B0107+B0087] Pi Zero cable set,
  • [B0077] Complete Pi camera cable set
MULTI-CAMERA ADAPTER COMPATIBILITY
  • [B0166] Dual-camera multiplexer,
  • [B0120] Quad-camera multiplexer,
  • [B0195] Synchronized Stereo Camera HAT
You can purchase this item from Arducam distributors or Arducam’s Amazon store
Selection Guide
Edit
