2.3MP USB3.0 UVC Global Shutter Dual-Camera Bundle Kit for Robotics & Machine Vision, Stereo Depth & Onboard ISP
Arducam AR0822 4K HDR High Framerate USB3.0 UVC Camera with onboard ISP for Quick PoC
Arducam UVC Camera with Supreme Ultra Low Light Performance, IMX662 sensor, Pre-tuned Lens, USB3.0 Interface, Long Exposure Supported
B0588
  • [Plug and play] USB 3.0 UVC compliant, no extra drivers needed
  • [Low Light Performance] Equipped with SONY STARVIS2 image sensor IMX662
  • [Onboard ISP] Proprietary on-board ISP advances image enhancement
  • [Selected Lens] M12 fixed focus lens for Precision focus and wide 98°(D) view
  • [Metal Housing] Carrying a CNC metal housing as both a heatsink and protection
  • [Long exposure support] Supports long exposure up to 12935800 us.
$147.99
The Arducam UVC Camera delivers exceptional imaging capabilities with its SONY STARVIS2 IMX662 sensor, ensuring superior ultra low light performance. Featuring a pre-tuned M12 fixed focus lens, it offers precise focus and a wide 98° diagonal field of view. The camera supports USB 3.0 UVC plug-and-play connectivity, requiring no additional drivers for easy integration. Its proprietary onboard ISP enhances image quality in real time, while the robust CNC metal housing provides effective heat dissipation and protection. Additionally, the camera supports long exposure times up to 12,935,800 microseconds, making it ideal for applications requiring detailed low-light or long-exposure imaging.
  • Surveillance and Security
  • Industrial Inspection
  • Scientific and Research Imaging
  • Traffic Monitoring
  • Robotics and Automation
  • Plug and Play USB 3.0 UVC Compliant The camera supports USB 3.0 with UVC (USB Video Class) compliance, allowing seamless plug-and-play operation. This means no additional drivers or software installations are required, enabling quick and hassle-free setup on a wide range of operating systems and devices.
  • Low Light Performance with SONY STARVIS2 IMX662 Sensor Equipped with the advanced SONY STARVIS2 IMX662 image sensor, the camera excels in ultra low light conditions. This sensor is specially designed to capture clear and detailed images even in near-dark environments, making it ideal for surveillance, industrial inspection, and scientific applications.
  • Onboard ISP for Image Enhancement The camera features a proprietary onboard Image Signal Processor (ISP) that performs real-time image enhancement. This ISP optimizes color accuracy, noise reduction, and overall image quality directly within the camera, reducing the processing load on the host device.
  • Selected M12 Fixed Focus Lens The pre-tuned M12 fixed focus lens ensures precise focusing with minimal adjustment needed. It provides a wide 98° diagonal field of view, allowing the camera to capture broad scenes without distortion, perfect for monitoring or capturing large areas.
  • Durable CNC Metal Housing The camera is encased in a robust CNC-machined metal housing that acts as both a protective shell and an efficient heatsink. This design helps dissipate heat generated during extended use, ensuring stable performance and longevity even in demanding environments. Long Exposure Support up to 12,935,800 Microseconds: Supporting long exposure times up to approximately 13 seconds, the camera can capture images in extremely low light or dark conditions by allowing more light to accumulate on the sensor. This feature is essential for applications like astrophotography, night surveillance, or scientific imaging where detailed long-exposure shots are required.
Sensor IMX662
Max Still Resolution 2 Megapixels
Optical Size 1/2.8″
Output Format YUYV
Pixel Size 2.9 µm x 2.9 µm
Sensor Active Area 1920(H) x 1080(V)
Frame Rate(USB3.0) YUYV 1920*1080@60fps, 1280*720@90fps
Frame Rate(USB2.0) YUYV 1280*720@10fps
Default Focus Range 3m-INF
FOV 98°(D)×85°(H)×69°(V)
F.NO F1.0
E.F.L 3.9mm
Power Consumption Max: 1.6W , Min: 0.8W
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Backlight Comp, Exposure (Manual/Auto)
Certification CE/RoHS
  • 1 x Arducam Ultra Low Light USB3 UVC Camera Module
  • Quick Start Guide
