Arducam UVC Camera with Supreme Ultra Low Light Performance, IMX662 sensor, Pre-tuned Lens, USB3.0 Interface, Long Exposure Supported
Arducam 3MP ISX031 USB3 UVC Camera – 120 dB HDR, Built-in ISP, LED Flicker Mitigation, Plug-and-Play for Windows and Linux
Arducam AR0822 4K HDR High Framerate USB3.0 UVC Camera with onboard ISP for Quick PoC
B0589
  • [Onboard ISP] Pre-tuned ISP right on the camera board
  • [4K HDR] onsemi AR0822 3840x2160 high resolution with HDR mode
  • [High Framerate] 60FPS @ 1080P Full HD for both UYUV & MJPEG
  • [Wide Angle] Selected M12 lens with DFoV 145°
  • [Easy Use] USB3.0 UVC, no drivers needed, plug and play
  • [Custom Supported] Incl. but not limited to Framerate, Lens options, External Trigger, FStrobe, etc.
$149.99
The Arducam 4K HDR USB3.0 UVC Camera, equipped with onsemi AR0822 4K HDR image sensor, combines ultra-high-definition 4K resolution with HDR imaging and a high 60FPS framerate for smooth, vibrant video capture. Featuring a pre-tuned onboard ISP, a wide-angle M12 lens with 145° field of view, and plug-and-play USB 3.0 connectivity, this camera is designed for quick and easy integration. Its customizable options, including framerate, lens types, and external triggers, make it ideal for diverse applications such as industrial inspection, robotics, and live streaming.
  • Drones: High-res aerial footage with smooth motion.
  • Sports: Capture fast action in soccer, tennis, and more.
  • Robotics: Vision for navigation and object detection.
  • Industrial Inspection: Detailed quality control imaging.
  • Live Streaming: Crisp video for events and webinars.
  • Security: Wide-angle, clear surveillance footage.
  • Scientific Research: High-quality data capture for experiments.
  • Onboard ISP: Features a pre-tuned Image Signal Processor on the camera board for fast, high-quality image processing without extra hardware.
  • 4K HDR: Delivers ultra-high-definition 3840x2160 resolution with HDR mode for clear, vibrant images in varied lighting.
  • High Framerate: Supports smooth 60FPS video at 1080p Full HD in both UYUV and MJPEG formats, ideal for real-time applications.
  • Wide Angle: Equipped with an M12 lens offering a 145° diagonal field of view to capture wide scenes easily.
  • Easy Use: USB 3.0 UVC interface requires no drivers—just plug and play for quick setup.
  • Custom Supported: Offers customizable options like framerate, lens choices, external trigger, and flash strobe control for versatile use.
Sensor Onsemi AR0822 Image Sensor
Still Resolution 8.3 Megapixels
Optical Size 1/1.8"
Output Format MJPG/YUV
Pixel Size 2 µm x 2 µm
Sensor Active Area 3840(H)×2160(V)
Frame Rate (MJPG) 3840x2160@30fps, 1920x1080@60fps; 1280*720@60fps;
Frame Rate (YUV(AI Resolution)) 640x480@60fps, 320x240@60fps; 320x320@60fps,128x128@60fps; 96x96@60fps;
FOV(DxHxV) 145°(D)×120°(H)×65°(V)
F.NO F1.5±5%
E.F.L 3.8±5% mm
Default Focus Range 260cm to infinity
TV-Distortion <-20.00%
Operating Voltage 5V +/- 5%
Power Requirements Max: 2.2W
Camera Board Size 34mm x 34mm
Exposure Time Range 1-66ms
UVC Controls Contrast, Saturation, Gain, Exposure (Manual/Auto)
Certification CE/RoHS
  • 1 x Arducam AR0822 4K HDR USB3 UVC Camera Module
  • 1 x 1m USB3 Type-C cable
Video Demo
