Arducam 5MP OV5647 Ultra Wide Angle Fisheye Camera for Raspberry Pi
Arducam 5MP OV5647 Fisheye Camera Module with M8 Lens for Raspberry Pi
Arducam 5MP OV5647 Camera Module Motorized IR-CUT Filter for Daylight and Night vision for Raspberry Pi
B003504
  • Switch daylight color accuracy and IR night vision automatically
  • Low-dispersion glass that greatly reduces focus shift and chromatic aberration, focusing different wavelengths of light onto the same image plane
  • Better Low Light Performance – IR corrected lens to reduce focus shift at night, and IR LED illuminator to improve the lighting condition
was $27.99 Special Price $23.99
This 5MP NOIR pi video camera is designed for both daylight and night vision photography with build-in IR cut filter and two infrared LED illuminator boards. The IR cut filter and the infrared LEDs are automatically ON/OFF according to the light environment. The camera is fully supported all the Raspberry Pi board versions including Pi3 and Pi Zero. It can be widely used in wild life photography, agriculture NDVI applications and etc.
  • Home surveillance
  • Smart Robots
  • Monitoring 3D printer
  • Wildlife photography
  • NDVI in agriculture, etc.
  • Day&Night Image: Built-in motorized IR-CUT Filter, switched in and out automatically based on light condition (only visible light during the daylight and infrared sensitivity during the night with IR LEDs on), has a better low light performance
  • Support all Raspberry Pi Models: Support Raspberry Pi Zero & W, Pi 5, 4 b, 3 b+, 3 b, and other A&B series
  • Acrylic Holder: Customized designed for this IR-CUT camera board and IR LEDs, make the camera stand or be mounted somewhere you like
  • Accessories - 2 heat sinks for IR LED boards and 1 ribbon cable for Pi Zero included. Contact Arducam for more lens options, technical support and customer services
    Sensor Omnivision 5647 sensor
    Sensor size 1/4” (OV5647)
    Resolution 5MP 2592×1944
    Video 1080p at 30 fps, up to 90 fps Video at VGA
    Focal Length 2.25mm
    Focus Distance 30 cm to infinity
    Field of View (FOV) 130°(D), 105°(H)
    IR Sensitivity Motorized IR Cut filter
    Power Output 3.3V power output for IR LED
    Dimension 36x36 mm, 4 screw mounting holes
    Peaking Current 300mA
    • 1pcs RPi IR-CUT Camera
    • 2pcs Infrared LED Board
    • 2pcs heat sink
    • 1pcs 15cm (5.9 inch) flat ribbon cable 15pin 1.0mm pitch to 15 pin 1.0mm pitch
    • 1pcs 15cm (5.9 inch) flat ribbon cable 15 Pin 1.0mm pitch to 22 pin 0.5mm pitch
    • If you have any requirement with the camera or other items, you can directly contact [email protected] for more help.
      Raspberry Pi 5 √ √
