Arducam 1080P Ultra Low Light 100 Degree Wide Angle USB2 UVC Camera Module
Arducam inVisCam 1080P Ultra Low Light Mini Size USB2 UVC Camera Module
Arducam True Day & Night Vision USB2 UVC Camera with IP65 Waterproof Housing
B0636
  • [True Day/Night Switching] Automatically switches between day and night modes for accurate color by day and clear IR imaging at night.
  • [Enhanced Low-Light Performance] Powered by Sony STARVIS 2 sensor and 8 integrated IR LEDs for excellent clarity in dark environments.
  • [Wide-Angle Coverage] 95掳 diagonal FoV fixed lens captures broad scenes with minimal distortion.
  • [Plug-and-play] USB 2.0 UVC compliant, instantly recognized on Windows and Linux without extra drivers.
  • [Waterproof Housing] IP65 Waterproof for outdoor applications.
  • [OEM/ODM] Customization options available.
$59.99
The Arducam True Day & Night Vision USB2 UVC Camera is designed for reliable imaging around the clock. Featuring a Sony STARVIS 2 sensor and auto-switching feature, it delivers vibrant color in daylight and crisp infrared images in darkness. With 8 built-in IR LEDs, excellent low-light sensitivity, and a 95° wide-angle fixed lens, it captures clear, expansive views in any lighting condition. Its durable metal housing and USB 2.0 UVC compliance ensure easy plug-and-play integration on Windows and Linux, while AI-friendly low-resolution YUV output makes it ideal for computer vision and edge AI applications. With IP65 waterproof metal housing, it can be used for multiple outdoor applications.
  • Security & Surveillance
  • Smart Home & IoT Devices
  • Robotics & Drones
  • Industrial Monitoring
  • Wildlife & Outdoor Observation
  • AI & Computer Vision Projects
  • True Day/Night Switching – The camera automatically switches between daytime and nighttime modes. This ensures accurate, natural color reproduction during the day and clear infrared-sensitive images in low-light or complete darkness.
  • Enhanced Low-Light Performance – Featuring a Sony STARVIS 2 image sensor with superior sensitivity, the camera maintains high-quality imaging even in dim environments. The 8 integrated IR LEDs provide additional illumination, enabling reliable performance where natural light is limited.
  • Wide-Angle Coverage – The fixed 95° diagonal field of view lens captures broad scenes with a single camera, reducing blind spots and minimizing the need for multiple units in coverage-critical applications.
  • Simple Plug & Play – Fully compliant with USB 2.0 UVC standards, the camera works instantly on Windows and Linux systems without the need for additional drivers or complex setup, making deployment fast and hassle-free.
  • AI-Friendly Streaming – In addition to full-resolution video, the camera supports low-resolution YUV output optimized for AI workloads. This allows developers to efficiently run computer vision algorithms and edge AI applications with reduced processing overhead.
Max Still Resolution 2 Megapixels
Optical Size 1/2.8″
Output Format MJPG/YUV/H.264
Pixel Size 2.9 µm x 2.9 µm
Sensor Active Area 1920(H) x 1080(V)
Frame Rate(MJPG/H.264) 1920x1080@30FPS, 1280x720@30FPS; 640x480@30FPS, 320x240@30FPS;
Frame Rate(YUV) 640x480@30FPS, 320x240@30FPS; 320x320@30FPS, 128x128@30FPS; 96x96@30FPS;
FOV 102°(D)×86°(H)×47°(V)
Lens Mount M12-S
F.NO F1.0
E.F.L 3.9mm
IR Sensitivity Sensitive to visible light during the day, sensitive to IR at night with 850nm IR LEDs on.
Default Focus Distance 300cm~INF
Distrotion TV Distortion: -10.4%; F-θ Distortion: -32.0%
USB Features
Interface USB 2.0 Device
Connector B4B-ZR JST
Supported OS Windows, Linux, Android
UVC Controls Brightness, Contrast, Gamma, Gain, Sharpness, Backlight Compensation, Lowlight Compensation, Exposure (Manual/Auto)
Power Consumption Max: 1.8W
Camera Board Size 38mmX38mmX1.6mm
Overall Weight (Net) 180g
Ingress Protection IP65
Certification RoHS
  • 1 x Arducam 1080P Day and Night Vision IP65 Waterproof USB2 UVC Camera Module
