Arducam True Day & Night Vision USB2 UVC Camera with IP65 Waterproof Housing
Arducam ezBOX-Slim 4K HDR Autofocus USB2 UVC Camera with CNC Enclosure
Arducam inVisCam 1080P Ultra Low Light Mini Size USB2 UVC Camera Module
B0630
  • [Miniature Form Factor] Features an ultra-compact 19.5×15×17.3 mm mini size for seamless and hidden embedding.
  • [STARVIS 2 Low Light] Leverages premium Sony STARVIS™ 2 technology for brilliant starlight-level clarity in near-dark environments.
  • [Low Power Consumption] Engineered with an energy-efficient architecture, minimizing power draw and reducing heat generation.
  • [1080P Full HD] Delivers crisp, detailed high-definition video at smooth frame rates for reliable monitoring.
  • [UVC Plug-and-Play] Driverless USB2 interface guarantees effortless integration across Windows, Linux, and Android.
  • [OEM/ODM] Customization options available.
$64.99
The Arducam inVisCam is a revolutionary 1080P ultra-low light mini USB2 UVC camera designed for tight, space-constrained installations. Measuring just 19.5×15×17.3 mm, this ultra-compact device features advanced STARVIS™ 2 starlight technology, capturing exceptionally clear and bright video where standard mini cameras see only darkness. Beyond its stealthy size and exceptional night-vision performance, it boasts remarkably low power consumption, making it ideal for continuous, long-term deployments. With driverless UVC setup, it offers a perfect balance of micro-sizing, high-sensitivity imaging, and effortless cross-platform integration.
  • Hidden & Discreet Surveillance: Perfect for covert security monitoring and undercover operations where cameras must remain completely unnoticed.
  • ATM and Kiosk Integration: Fits effortlessly into slim bezels of self-service kiosks, ticketing machines, and automated banking systems.
  • Medical Equipment Inspection: Ideal for micro medical imaging systems, dental cameras, or diagnostic devices with strict space limitations.
  • Portable & Wearable Devices: Excellent for compact body-worn tech, dashcams, or handheld battery-operated instruments requiring low power.
  • [Ultra-Compact Mini Design] With a miniature housing of only 19.5×15×17.3 mm, the inVisCam can be easily concealed or embedded into extremely narrow, space-critical applications without compromising performance.
  • [Next-Gen STARVIS™ 2 Sensitivity] Powered by cutting-edge starlight sensor technology, it significantly enhances near-infrared sensitivity and light intake, providing vibrant, low-noise Full HD visuals under challenging lighting.
  • [Eco-Friendly Low Power Draw] Optimized for high efficiency, its low-power architecture prevents overheating during prolonged operation, making it ideal for battery-powered systems or enclosed setups with limited ventilation.
  • [Crisp Full HD 1080P Capture] Delivers exceptionally sharp, distortion-free 1080P high-definition video streams with high dynamic range, ensuring precise facial identification and fine detail recognition in real-time.
  • [Instant UVC USB Plug-and-Play] Fully driverless and compliant with UVC specifications, it works immediately upon connection, ensuring seamless and hassle-free compatibility with modern operating systems and vision frameworks.
Still Resolution 2 Megapixels
Optical Size 1/2.8"
Output Format MJPG/YUY2/H.264
Pixel Size 2.9μm x 2.9μm
Sensor Active Area 1920(H) x 1080(V)
Frame Rate (MJPG/H.264) 1920×1080@30fps, 1280×720@30fps; 800×600@30fps, 640×480@30fps, 320×240@30fps;
Frame Rate (YUV) 640×480@30fps, 320×320@30fps; 320×240@30fps; 128×128@30fps; 96x96@30fps
FOV 95°(D) ×82° (H)×66°(V)
Lens Mount M12-S
F.NO F2.5
E.F.L 3.7mm
Default Focus Distance 100cm~INF
Distrotion <-13%
USB Features
Interface USB 2.0 Device
Connector USB Type-C
Supported OS Windows, Linux, Android and MacOS
UVC Controls Brightness, Contrast, Gamma, Gain, Sharpness, Backlight Compensation, Lowlight Compensation, Exposure (Manual/Auto)
Power Consumption 1.2W
Camera Board Size 19.5×15×17.3 mm
Overall Weight (Net) 12g
Certification RoHS
  • 1 x Arducam inVisCam 1080P Camera Module with USB Type-C Cable (1m)
  • 1 x USB Type-C to USB A adapter
