In order to meet the increasing need for Raspberry Pi compatible camera modules. The Arducam team now released another add-on spy camera module for Raspberry Pi series boards which is fully compatible with the official one.
The board itself is tiny, at around 300mm x 16mm. The neck width of the camera module is 6mm, this highlight making it perfect for an endoscope, spy surveillance or other applications where size and image quality are important. It connects to Raspberry Pi by way of a short ribbon cable. The camera is connected to the BCM2835/BCM2836 processor on the Pi via the CSI bus, which travels along the ribbon cable that attaches the camera board to the Pi.
| Sensor | Omnivision OV5647 sensor |
| Sensor size | 1/4” (OV5647) |
| Resolution | 5MP 2592×1944 |
| Video | 1080p 30 fps, 720p 60fps, 480p 90fps |
| IR Sensitivity | Integral IR Filter |
| Focus Distance | 1 m to infinity |
| Field of View (FOV) | 62°(H), 47°(V) |
| Focus Type | Fixed |
| Full-frame SLR lens equivalent | 35 mm |
| Lens Type | Stock Lens |
| Dimension | 300 x 16 mm flex cable, neck wide is 6mm |
| Peak Current | 300mA |
Introduction In order to meet the increasing need of Raspberry Pi compatible camera modules. The ArduCAM team now released another add-on spy camera module for Raspberry Pi series boards which is fully compatible with official one. The board itself is tiny, at around 300mm x 16mm. The neck width of the camera module is 6mm, […]
