Arducam Ultra Low Light 2MP IMX462 STARVIS Camera, 1080P HD Wide Angle Pivariety Camera Module for Raspberry Pi
Arducam 5MP OG05B10 95°(DFOV) Color Global Shutter Camera for Raspberry Pi
Arducam Pivariety 21MP IMX230 Color Camera Module for RPi 5, 4B, 3B+, 3A+, CM3/CM4 and Jetson Board
B0324
  • High Resolution: 21MP Sony IMX230 Exmor RS™ color sensor, up to 5344×4012@9 fps.
  • Gstreamer support.
  • ISP Support (Only for Raspberry Pi): Auto Exposure, Auto White Balance.
  • Autofocus: Motor Driver. Programmable focus control.
  • Wide Compatibility: Compatible with all libcamera-based apps maintained by the RPi foundation.
  • USB 3.0 quick development and evaluation board is for sensors like IMX230.
$99.99
Arducam IMX230 AF Camera is a high-resolution camera solution for the Raspberry Pi and NVIDIA Jetson. Using the Arducam IMX230 camera module, users can enjoy higher resolution and faster focus imaging, significantly reducing development costs and cycle time. The Arducam IMX230 camera offers a carefully calibrated image sensor on the Raspberry Pi platform, with features such as auto-exposure, auto-white balance, and lens shading correction (this feature is not currently supported on the NVIDIA Jetson).
  • UAV/Drones/FPV camera
  • Machine Vision
  • Robotics
  • IoT
  • Face Recognition
  • Defect Detection
Sensor Type Sony 21MP IMX320
Pixel Size 1.12um x 1.12um
Optical Size 1/2.4”
Active Pixels 5344(H)x4016(V)
Sensor Output Format RAW10
ISP Output Format (for Raspberry Pi Only) JPG, YUV420, RAW, DNG; MJPEG, H.264
Interface Type 2-lane MIPI CSI-2
Frame Rates 5344x4012@9 fps, 3840x2160@10 fps, 2592x1944@15 fps, 2656x2004@30 fps, 1920x1080@30 fps, 1280x960@120 fps, 1280x720@120 fps, 640x480@120 fps
Focal Length 4.77mm
F.NO 1.75±5%
FOV 64°(H)
Focus Type Motorized focus, programmable focus control
Board Size 38mm x 38mm
    Raspberry Pi 5
    • Due to the hardware limitations of the NVIDIA Jetson platform, this product does not support ISP functionality. If a pre-tuned ISP solution is required, please refer to Arducam xISP series or Arducam TrueSight Series
    • Only support the camera interface close to the NVIDIA Jetson carrier board power interface.
    • 1 x Arducam 21MP IMX230 AF Camera Module
    • 1 x 150mm 15-22pin FPC cable
    • 1 x 150mm 22-22pin FPC cable
    Pivariety IMX230 21MP Motorized Focus Camera Module
    1. Introduction Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver […]
    Install and build Raspberry Pi Kernel Driver for Arducam Pivariety Camera
    In order to ensure the normal working of the hardware, the driver needs to operate according to standard procedures. These operations are cumbersome. Generally, only the hardware manufacturer understands the specific details. One of the main tasks of the driver is to ensure that the hardware works as expected according to the standard procedure and […]
    3D drawing.step
    Datasheet
