OAK-SoM MAX
OAK-SoM MAX
Arducam 5MP OV5647 Miniature Camera with Flex Cable for Raspberry Pi Zero and Compute Module (NoIR)
Arducam Ultra Low Light 2MP IMX462 STARVIS Camera, 1080P HD Wide Angle Pivariety Camera Module for Raspberry Pi
B0333
Discontinued, check alterative item B0444
  • Based on Sony 2MP IMX462 STARVIS color sensor
  • Ultra Low Light: Minimum illumination: 0.01Lux
  • Wide Aperture: F.N0 0.95(Allow more light enter)
  • ISP Support: Auto exposure, auto white balance
  • Wide Compatibility: Compatible with all libcamera-based apps maintained by the RPi foundation, like Gstreamer, OpenCV
  • More Applications: Night vision, home security, machine vision and so on
$59.99
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Lens Shading Correction, etc.
This B0333 is a new member of the Arducam Pivariety series, which adopts an IMX462 low light sensor and also supports hardware ISP functions like AEC/AGC, etc. That is to say, with this Pivariety, you can get much more decent image quality compared with the Official cameras under low light conditions.
  • Surveillance cameras
  • FA cameras
  • Industrial cameras
Sensor SONY STARVIS IMX462
Optical Size Type 1/2.8'' (Diagonal 6.46 mm)
Pixel Size 2.9μm×2.9μm
Minimum illumination 0.01Lux
Shutter Type Rolling Shutter
Max Sensor Resolution 1920 x 1080, 2MP
Color Filter Array Bayer RGB
Resolution and Frame Rate 5-60fps@1080P
Supported Platform Pi 5/4/3/Zero/CM3/CM4
Camera Interface 2-lane MIPI
Output Format RAW10
ISP Output Format JPG, YUV420, RAW, DNG; MJPEG, H.264
Focus Type Manual
Lens Type M16 Lens
F.NO 0.95±5%
Focal Length 4mm±5%
FOV(Field of View) 92°H
IR Sensitivity Integral IR cut filter
Dimensions 38mmx38mm
Hold Pitch Compatible with 34mm×34mm, 28mm×28mm
  • 1 x Arducam 2MP IMX462 ISP Camera Module
  • 1 x 150mm 15pin 1.0mm to 22pin 0.5mm pitch FPC cable
  • 1 x 150mm 22pin 0.5mm to 22pin 0.5mm pitch FPC cable
  • 1 x acrylic case kit with assembly accessories
  • Pivariety Driver can only work with libcamera instead of raspistill/raspivid application
  • Due to the limitation of the platform and driver, the output format of the camera is changed from the highest RAW12 output to RAW10.
    Raspberry Pi 5 √ √
  • Quick-Start-Guide
  • User guide_Assembly.pdf
  • Acrylic Bracket Assembly Guide.pdf
  • 3D drawing.step
  • Dimension
    arducam-doc-logo-150-150 00244AF8 C7B9 4134 A91A 8239833DEA1F
    Additional information
    The spectral transmission properties for the Bayer filter on the IMX462 sensor
