Arducam 8MP IMX219 USB2.0 Camera Module with 300mm Extension Cable
Arducam Mini 5MP OV5647 Camera Module for Raspberry Pi 4/3B+/3 (NoIR)
Arducam 2MP Ultra Low Light STARVIS IMX462 Motorized IR-CUT Camera for Raspberry Pi
B0423
  • Low Light: Ultra low light Sony STARVIS IMX462 sensor
  • Motorized IR-Cut: Motorized IR-CUT function under different lighting condition
  • High Frame Rate: 90fps at 1280×720 resolution, 46fps at 1920×1080
$69.99
Arducam 2MP IMX462 Motorized IR-CUT Camera is capable of capturing visible and near-infrared images with very low noise even in extremely low-light conditions or no light (near 0 lux). This high-speed camera captures uncompressed Full HD images at 50fps at full resolution. This is great for minimizing inter-frame distortion and reducing motion blur, resulting in sharper images with more scene detail when capturing moving objects. High sensitivity, low dark current and no smear can be achieved through the adoption of R, G and B primary color mosaic filters.
  • Surveillance cameras
  • FA cameras
  • Industrial cameras
  • Input frequency: 74.25 MHz / 37.125 MHz
  • Pixels: Approx. 1920 (H) × 1080 (V) 2.07 million pixels
  • Maximum frame rate in Full HD 1080p mode: 30 fps
  • High Dynamic Range (HDR) function: Multiple exposure HDR, Digital Overlay HDR
  • 10-bit/12-bit A/D converter
  • CSI-2 serial data output: 2 Lane, RAW10 / RAW12 output
Sensor SONY STARVIS IMX462
Optical Size Type 1/2.8'' (Diagonal 6.46 mm)
Pixel Size 2.9μm×2.9μm
Number of the Active Pixels 1920x1080
Color Filter Bayer RGB
Frame Rates 1920x1080@60fps;1280x720@60fps
Supported Platform Pi 4/3/Zero/CM3/CM4
Output Format RAW10/RAW12
F.NO 1.6±10%
Effective Focal Length 4.3±5%mm
MOD. 2.0
Back Focal Length 5.43±0.2mm
Field of View(FOV) 103°(D)x90°(H)x74°(V)
IR Sensitivity Motorized IR-cut
Camera Board Size 38mm x 38mm
Comparasion
Among the Sony STARVIS series sensors, IMX290, IMX462, and IMX327 are some of the more popular ones. Though they are all belong to the STARVIS series, there are some differences between them. Please see the following table about the similarities and differences:
Specifications Sensor
IMX462 IMX290 IMX327
Mega Pixels 2.10MP 2.07MP 2.07MP
Max Resolution 1920x1080 1920x1080 1920x1080
Optical Size 1/2.8'' 1/2.8'' 1/2.8''
Pixel Size 2.9μm×2.9μm 2.9μm×2.9μm 2.9μm×2.9μm
G Sensitivity* 10471 5486 10471
Max Frame Rate 120fps(sensor) 120fps(sensor) 90fps(sensor)
NIR Sensitivity(850nm)* ~1 ~0.5 ~1
G Sensitivity*: Gravity sensitivity is an important indicator of camera performance in low light conditions. Higher the G sensitivity, better is the low light performance.
NIR sensitivity*:NIR imaging performance is one of the most crucial features for smart surveillance, smart traffic monitoring, and agricultural applications.
  • If low light sensitivity is your key requirement, then choosing IMX462(B0423) and IMX327(B0425) will better suit your requirements
  • If you need a higher frame rate for your project, then the higher frame rate IMX462(B0423) and IMX290 (B0424) will be your first choice
  • Among the above three sensors, IMX462 has relatively high near-infrared sensitivity. If you need this feature more, it is recommended that you choose IMX462 (B0423)
  • 1 x IMX462 Motorized IR-CUT Camera Module
  • 1 x 150mm 15pin to 22pin flex cable
  • 1 x 150mm 22pin to 22pin flex cable
  • For any issues when using the camera, you can directly contact Arducam Support.
  • If you have any custom requirements for this camera module, you can directly contact Arducam Sales for help.
Raspberry Pi 5
