[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi With Fisheye Lens Pivariety
[Discontinued] Arducam HD Wide Angle USB Camera Board, High Frame Rate 30fps@5MP HDR Video Webcam 1/2.8” IMX335 UVC Camera Module with Microphones
[Discontinued] Arducam OG02B10 2MP Global Shutter USB Camera Evaluation Kit - 1/2.9-inch Color M12 Camera Module with USB3.0 Camera Shield Plus
B0351
Discontinued, check alternative item EK031.
$249.99
The Arducam OG02B10 color global shutter supports embedded systems such as PC and Raspberry Pi well, and can also provide customized support TK/TX boards for Odroid, Beaglebone Black, and Nvidia JETSON.
  • Drones
  • 3D imaging
  • Machine vision
  • Industrial automation
  • Sensor: Color global shutter OG02B10
  • Pixel Size: 3 μm x 3 μm
  • Active array size: 1600H×1300V
  • Optical Size: 1/2.9 inch
  • Output formats: 8/10-bit BW RAW
  • Frame Rate: 1600×1300@60fps; 1600×1080@80fps; 1280×720@120fps
  • Lens: M12 lens mount, focal length of 2.8mm±5%, F/2.8±5%, 110 degrees horizontal field of view (HFoV)
  • Board Size: 40mm x 40mm
    OG02B10 MIPI Camera with USB3.0 Camera Shield Plus
    1.Introduction Arducam USB3 camera Shield board is the latest super high-speed USB camera expansion board, which provides improved performance and enhanced functions than the previous USB2.0 camera expansion board. It not only supports high resolution and high frame rate image sensors but also supports stereo camera and IRCUT control functions. Using a given camera profile, […]
    • 1 pcs Arducam OG02B10 1/2.9-inch Color M12 Camera Module
    • 1 pcs Arducam USB3.0 Camera Shield Plus
    • 1 pcs USB3 Cable
