Ultra HD Resolution: This camera adopts the 5MP IMX335 Color COMS sensor for sharp images and accurate color reproduction with 72DB high dynamic range.
Wide Angle: Assembled with a 75-degree horizontal view angle M12 lens with IR filter, which provides a much wider Field of View.
High Frame Rates: MJPG?30fps@2592?x 1944/2048 x 1536;?30fps@1080P/720P/1024 x 768/800 x 600; YUY2?20fps@800?x 600;?3fps@1920?x 1080;?30fps@640?x 480.
Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
Applications: Highly recommended for the video surveillance system, live streaming, videoconference, dashcam, and other video vision applications need high frame rates with high resolution.
Arducam UB0236 is a 5MP, based on the 1/2.8" IMX335 image sensor, UVC compliant, wide angle USB 2.0 camera.
Ultra HD resolution and high frame rate meet your request for higher quality video and still pictures resolution.
High Frame Rates: MJPG 30fps@2592 x 1944/2048 x 1536; 30fps@1080P/720P/1024 x 768/800 x 600; YUY2 20fps@800 x 600; 3fps@1920 x 1080; 30fps@640 x 480.
Live streaming
Videoconference
Monitoring 3D printer
Dashcam
- Sensor: 1/2.8” IMX335
- Resolution: 5MP 2592 x 1944
- Dynamic Range: 72DB
- Frame Rate: MJPG 30fps@2592 x 1944/2048 x 1536; 30fps@1080P/720P/1024 x 768/800 x 600; YUY2 20fps@800 x 600; 3fps@1920 x 1080; 30fps@640 x 480.
- Field of View (FOV):75 degree (H)
- Lens Mount: M12
- IR Sensitivity: Integral 650nm IR filter, visible light only
- Adjustable parameter: Contrast/ Saturation/ Exposure/ White balance
- Audio: Dual microphones
- System Compatibility: Win7/8/10, Linux, Mac OS with UVC driver
Power
- Working Current: MAX 300mA
Physical
- Dimension: 38mmx38mm
- Hole Pitch: compatible with 34x34mm, 28x28mm
- Cable Length: 3.3ft (1M)
Manual.pdf
