[Discontinued] Arducam 3MP WDR USB Camera Board with M12 Lens, Dual Microphones 1/3
[Discontinued] Arducam 3MP WDR USB Camera Board with M12 Lens, Dual Microphones 1/3" AR0331 CMOS Senor USB Audio Webcam Module for Computer, Laptop, Android Device, and Raspberry Pi
[Discontinued] Arducam OG02B10 2MP Global Shutter USB Camera Evaluation Kit - 1/2.9-inch Color M12  Camera Module with USB3.0 Camera Shield Plus
[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi With Fisheye Lens Pivariety
B0350
  • High Resolution: Based on Sony 8MP IMX219 Image Sensor
  • Complete Synchronization: The frames of dual cameras is synchronized in hardware level
  • ISP Support: Support Raspberry Pi hardware ISP function, auto exposure/gain, auto white balance
  • Easy to move: Connected with a Arducam Cammrray HAT and two flexible cable, allows flexible movement of the camera.
$169.99
IMX219 Camera Module is the native V2 camera of Raspberry Pi. Official Raspberry Pi V2 Cameras are always one single camera. But for some clients who need the IMX219 Camera as well as multi-camera, we have designed and devoloped the Arducam IMX219*2 stereo syncronized camera bundle kit. Unlike the previous IMX219 stereo camera kit, this camera support the ISP function, the Pivariety Solution.
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Auto Gain Control, Lens Shading Correction, etc.
  • Robot navigation
  • Objective tracking
  • 3D measurement
  • 3D reconstruction
  • Depth-related vision applications, etc.
Sensor Sony IMX219 sensor
Optical size 1/4” (IMX219)
Pixel Size 1.12μm(H)×1.12μm(V)
Resolution 8MP, 3264*2(H)×2464(V)
Frame Rates 1600×600@21fps; 2560×720@37fps; 3840×1080@17fps; 5184×1944@8fps; 6528×1848@7fps; 6528×2464@5fps
Sensor Output Format RAW10
ISP Output Format JPG, YUV420, RAW, DNG; MJPEG, H.264
IR Sensitivity Integral IR Filter, visible light only
Horizontal Field of View (HFOV) 220°
Effective Focal Length 0.76mm±5%
F.NO 2.1±5%
Focus Type Manual
Lens Type M12 Lens
Camera Board Size 25mm x 24mm
Camarray HAT Size 65mm x 56mm
  • 1 x Arducam Synchronized Stereo Camera HAT for Raspberry Pi
  • 2 x 8MP IMX219 color camera module mounted with M12 lens
  • 2 x Arducam 73mm 15pin to 22pin Ribbon Cable
  • 1 x Arducam 150mm 15pin to 22pin Ribbon Cable
  • 4 x M2.5*11mm Hex Standoffs
  • 4 x M2.5 Nuts
  • 3 x M2.5*6mm Screws
  • This bundle kit is not recommended for Raspberry Pi Zero.(Due to the limitation of the memory)
  • The IMX219 cameras in this kit are customized and cannot be used on Raspberry Pi individually.
  • The I2C signal and clock of each camera are fully synchronized. It is unavailable to capture the same frame of images at different exposure times/gains for each camera.
  • Our main business is to assist customers in acquiring data from binocular cameras. Due to the extensive backend processing involved in depth vision, we regret that we cannot provide comprehensive operational guidance to cover all requirements. If you have relevant needs, you may refer to open-source demos for binocular cameras, such as those offered by NVIDIA.
  • This camera module supports the latest Raspberry Pi OS Bullseye (Jan 28th, 2022 and later) and libcamera apps, for the previous Raspberry Pi OS (Legacy) users, please contact [email protected].
Pivariety IMX219 8MP*2 360 Degree Panoramic Camera Module
1.Introduction Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and […]
Dimensions
HATCamera
