Arducam 2MP OV2640 1/4” Camera Breakout Board
Arducam 5MP MT9P001 Color Arducam Camera Breakout Board  w/M12 lens (6mm lens)
Arducam 0.36MP MT9V022 Monochrome 1/3” CMOS Camera Module
B0109
More:
USB 3.0 quick development and evaluation board for sensors like MT9V022.
$49.99
The MT9V022 is a 1/3-inch monochrome wide-VGA format CMOS active-pixel digital image sensor with a global shutter and high dynamic range (HDR) operation. The sensor has specifically been designed to support the demanding interior and exterior surveillance imaging needs, which makes this part ideal for a wide variety of imaging applications in real-world environments. High frame rate, high dynamic range, good sensitivity for machine vision with an external trigger.
  • 1/3" optical format
  • 0.36MP 752 x 480 MT9V022 global shutter sensor
  • 6.0 x 6.0 um Pixel size
  • 60fps at full resolution
  • 4.8V/lux-sec responsivity
  • 55db linear, 110db HDR dynamic range
  • single 3.3V power input
  • Default M12 mount 6mm LS-6020 lens
  • Security
  • High dynamic range imaging
  • Unattended surveillance
  • Stereo vision
  • Video as input
  • Machine vision
  • Automation
  • 1 pcs Arducam CMOS MT9V022 1/3-Inch 0.36MP Monochrome Camera Module
  • NOTE: The camera module only can be used together with Arducam USB shield
    User guide.pdf
    Application note.pdf
    Github
    ArduCAM/RaspberryPi
    Arducam USB3.0 Camera Shield
