[Discontinued] 8MP IMX179 with 150° Wide Angle M12 Lens Camera Module-Arducam
[Discontinued] Arducam 3MP WDR USB Camera Board with M12 Lens, Dual Microphones 1/3
[Discontinued] Arducam 3MP WDR USB Camera Board with M12 Lens, Dual Microphones 1/3" AR0331 CMOS Senor USB Audio Webcam Module for Computer, Laptop, Android Device, and Raspberry Pi
[Discontinued] Arducam MT9V022 0.36MP Global Shutter USB Camera Evaluation Kit - 1/3-Inch Monochrome Camera Module with USB2 Camera Shield
EK002
Discontinued, check alternative item EK025.
Note: The product has been changed and the information?will be?updated soon.
$134.99
The MT9V022 is a 1/3-inch monochrome wide-VGA format CMOS active-pixel digital image sensor with global shutter and high dynamic range (HDR) operation. The sensor has specifically been designed to support the demanding interior and exterior surveillance imaging needs, which makes this part ideal for a wide variety of imaging applications in real-world environments.
High frame rate, high dynamic range, good sensitivity for machine vision with external trigger.
  • 1/3" optical format
  • 0.36MP 752 x 480 MT9V022 global shutter sensor
  • 6.0 x 6.0 um Pixel size
  • 60fps at full resolution
  • 4.8V/lux-sec responsivity
  • 55db linear, 110db HDR dynamic range
  • single 3.3V power input
  • Default low distortion M12 mount 2.8mm lens (Part Number: M27280M07S)
  • Security
  • High dynamic range imaging
  • Unattended surveillance
  • Stereo vision
  • Video as input
  • Machine vision
  • Automation
Documentation:
Datasheet_sensor.pdf
0.36MP MT9V034/MT9V022 Global Shutter
Introduction Arducam MT9V034/MT9V022 camera breakout incorporates ON Semiconductor 1/3−inch 0.36 Mp CMOS digital image sensor with an active-pixel array of 752 (H) × 480 (V) ,global shutter and high dynamic range (HDR) operation. It can support 0.36 megapixel (752H x 480V) digital still images and a 480p (640H x 480V) digital video mode. MT9V034/MT9V022 has […]
Posts not found
Arducam USB Camera Shields
Posts not found
GitHub:
ArduCAM_USB_Camera_Shield
Package Including:
  • 1 pcs Arducam CMOS MT9V022 1/3-Inch 0.36MP monochrome Camera Module
  • 1 pcs Parallel Camera Adapter Board for USB Camera Shield
  • 1 pcs USB Cable
